DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
Changing rear tag holder without disconnecting tag light (636 '05+).
Old Jul 18, 2006 | 11:33 PM
xrider's Avatar
Default Changing rear tag holder without disconnecting tag light (636 '05+).
I recently purchased a license plate holder to get rid of the original ugly rear guard and tag holder. I was told that you had to remove a lot of things just to get the rear tag light plug through the hole. I found that the tag light can actually be taken apart then threaded through the new and old pieces.
Disassembly:
First, remove the tag light from the fender (2 screws on the inside of the fender). Next, take the cover off (2 screws) and the chrome reflector, the bulb should now be removed. Once that is done just the rubber insulation and metal socket are still together (the plastic backing is there but it falls off once you get the other 2 pieces apart). To get the socket out of the rubber piece just pull the rubber insulation up from the bottom, working it over the socket little by little with the tips of your fingers while pushing down in the middle of the socket with your thumb (make sure the top lip on the socket is down through the rubber before you get too far). At first it feels very firm and gives a lot of resistence but once its starts to go it gets easy. Reassembly is much easier.
[IMG]local://upfiles/2215/DCC9D70390D34A119D0E9FFB54D12200.jpg[/IMG]
Old Aug 2, 2006 | 06:11 AM
evil636's Avatar
Knee Dragging Pimp
Default RE: Changing rear tag holder without disconnecting tag light (636 '05+).
damm bro, who knew
canehdian_guy
Apr 18, 2015 08:27 PM
rdub429
Jul 17, 2008 06:15 PM
Funkdock
Sep 16, 2007 05:50 PM
Nobrakes
Feb 5, 2007 05:37 PM
shinobi636
Jan 5, 2007 05:25 AM
