Please help electrics
Old Nov 5, 2017 | 05:21 PM
Terry Powick's Avatar
Default Please help electrics
I have a klx 250, after going for a long ride 5 minutes in return bike wouldn’t start. I have a new battery which I have also replaced so I’m now on second New battery. I can run start and runs fine, light blinkers ect all work so the battery not draining. I only have electric start when press button I can hear the starter clicking over. Was going to take it to mechanic but thought I’d check here first Incase it’s something easy to fix cheers
Old Nov 5, 2017 | 06:29 PM
canklx's Avatar
Check to make sure the battery terminals are tight and clean.
Old Nov 5, 2017 | 08:55 PM
GBAUTO's Avatar
You'll need a voltmeter to diagnose this. Normal battery voltage w/engine off is usually above 12.5V When the engine is running is should be above 14V. The shop manual pdf file has the steps to find out what's wrong-look at it.
Old Nov 5, 2017 | 11:46 PM
durielk's Avatar
You have a new battery, how long did you charge it?
How long is your typical trip?
WestOzKLX
Nov 12, 2009 11:32 AM
banger73
Oct 3, 2008 06:25 PM
marcus446
Feb 26, 2008 10:22 PM
pyramidialmind
Jan 11, 2008 12:09 AM
pault
Oct 8, 2007 01:28 PM
