Pipe. Is it worth it?
Old Apr 10, 2009 | 05:17 AM
redpillar's Avatar
If you have the money to spend then I think it is worth it. but you can get great results with the 300 pipe and buying a couple of jets from kawasaki. The jet kits are expensive and give you way more than you need in my opinion.
Old Apr 10, 2009 | 05:19 PM
Kirkland Jeff's Avatar
I say go for the pipe. Do it cheap or expensive, you will love it. For the record, mine is Muzzy and is way too loud but I haven't been pulled over yet. The Muzzy seems to have the most Peak power while others have more torque. For my mostly gravel road high speed stuff I think it's perfect, trail riders might like something else better.
Old Apr 10, 2009 | 06:38 PM
roadglider's Avatar
Might want to try it in stages as opposed to blowing your wad (of cash) all at once. Remove the snorkle and put the DJ jet kit in or use a larger main jet (which one to use depends on a few factors most people post that they are running a 128) an N1TC needle (third groove) and remove the Welch plug over the idle mixture screw and back it out approxmatley 2.5 turns (again exact setting depends). That and new tires, a 13 tooth countershaft sprocket (which you have) made a noticeable improvement in my bike. I want to keep my bike as quiet as possible so haven't replaced the exhuast.
Old Apr 11, 2009 | 04:16 AM
NEWPARTSRULE's Avatar
Do the pipe, man. Along w\ jets you will notice a big difference. Planet KLX shows a cut up stock muffler, check it out. Chaparral Motosports will ship you a fender.
Old Apr 12, 2009 | 02:19 PM
SnowmanSimon's Avatar
Fill me in on the intake mods. I'm going to hold off on the pipe for a couple weeks. What can I do with the stock intake? Will I need to rejet?
Old Apr 14, 2009 | 01:12 AM
Ive been reading around and have ordered:
blinkers from cyclegear.com
uni filter locally
koubalink fuelscrew carlscycle.com
going to order a two brothers exaust
ordering the kdx200 snorkle...what year bike is it for? Should I bother or just remove the stock one?
What jet kit should I be looking for?
Any pictures of the carb for drilling the 7/64th hole I have been reading about?
Also read about plugging 2 holes? I think this might be on the bikes from australia?
Old Apr 14, 2009 | 03:06 AM
WestOzKLX's Avatar
uni filter locally
Jet kit is Dynojet for the KLX300R. (Best needle taper.)
Drill the hole next to the one the needle exits from. Easy.
No holes to fill unless you enjoy roo tails on the barbi and can drink **** all day. LOL.
Save your money on the snorkel and just remove the entire lid.
Old Apr 14, 2009 | 10:03 AM
remove the lid even in woods? Im thinking the lid would be a little safer in really deep crossings. Is there much of a difference between the lid removed and the kdx snorkle?
Old Apr 14, 2009 | 03:40 PM
WestOzKLX's Avatar
Learn to mono the crossings.
It's your choice. I run no lid but rain is a rarity here for 6 months of the year.
Last time I came across a deep ford i just carried the bike on my back.
IRON MEN live down here.
Old Apr 14, 2009 | 10:19 PM
armycopter's Avatar
Here's a little article I found helpful on jetting and exhaust....
http://www.motorcycleproject.com/mot...s-jetting.html
There are all sorts of opinions out there. Some people think exhausts are mandatory, others do not. As for me, I'm leaving the pipe for last since there are plenty of other mods to do in the meantime.
