Phone Charger/Power Options
Old Feb 26, 2020 | 08:18 PM
philgoodklx's Avatar
Originally Posted by klx678
Gee, oddly enough that first one posted has a plug in for the battery that looks awful familiar - couldn't also be hooked up to a Battery Tender too, could it? (Rhetorical question)
Why would you want one w/o a on/off switch?
Old Feb 27, 2020 | 01:06 AM
Old Feb 27, 2020 | 04:33 PM
ForestThump's Avatar
Originally Posted by ALONEINTHEHILLS
Yes, just a few zip ties to the small crossbar and it's nice and stable.
OK, probably a stupid question. But if the USB port is zip tied to the handlebars, what kind of cord are you running between there and phone or other electronic device?
Considering it's about 10 inches between the port and phone mount or tank bag, I rather assume you don't have like 6 feet of cord hanging out there?
Old Feb 28, 2020 | 04:58 AM
ALONEINTHEHILLS's Avatar
I have some cords that are short that came with things like battery charging packs. Probably 18", figure out what you want then ebay should have that length if you don't have a random box of old cables lying around. Any excess just gets folded and secured to the arm of my ram mount so it doesn't look too sloppy.
To the other question, yep two wires going to the battery with a fuse and the right connector so it sure looks like a tender setup.
Old Feb 28, 2020 | 04:46 PM
Topher749's Avatar
I installed a perfect squeeze with built in wireless charger on my KLX. I ran power to an Eastern Beaver fuse block that I use to run my heated grips, USB and phone charger. Works pretty well. Hardest part was finding a location to put it. There is not much room under the hood.
Toph
Old Feb 28, 2020 | 09:43 PM
Toph
Without a photo it's not so good.
Old May 21, 2020 | 05:00 PM
Thought I would come back and update with what I did.
I bought dual port USB charger from Amazon that has an on/off switch. It connects to an SAE adapter which, in turn, is wired directly to the battery (with an inline fuse), and I didn't want this thing draining the battery. I've had the bike parked in the garage for 2-3 weeks at a time with the switch turned off, and the bike starts just fine. So there does not appear to be any battery draw. (I haven't put a multi-mater on there to verify this, though) The USB charging device has a built-in voltage read-out, so that's a nice added bonus to keep an eye on my charging system while underway.
I also bought a 12-inch cable to attach to my phone, and the cable has a 90-degree fitting so the cord tucks away nicely when in use and I don't have a cord hanging down to obstruct the throttle or any of the other controls on the handlebars.
I'm happy with the end result.
Brieninsac
Dec 8, 2015 12:00 AM
marcham
May 11, 2015 02:43 PM
Arickrock
Nov 23, 2013 11:19 PM
ahnh666
Dec 20, 2011 03:36 AM
Senator24
Feb 17, 2010 01:03 AM
