Phone Charger/Power Options
Old Feb 22, 2020 | 03:47 PM
ForestThump's Avatar
Default Phone Charger/Power Options
I ran my phone (which doubles as my mapping/GPS unit) dead on a short 2 hour ride yesterday. Not a huge deal as I was in familiar terrain. But it's time to add a power point to my handlebars, to charge the phone when I'm much further out in the boonies later this summer.
A search on here didn't really turn up any recent discussion lately.
For those of your who have added power points on your KLX, care to share what you've done? Pics and part numbers would be awesome.
Old Feb 22, 2020 | 07:14 PM
ALONEINTHEHILLS's Avatar
I run this:
Amazon Amazon
It charges my phone and garmin fine. It must use a cheap transformer with a high quiescent current though because even though it has no LEDs it will drain the battery if I leave it connected. I ran it so the disconnect is right by my fuel shutoff so can easily disconnect it when not in use. It should be able to double as a tender plug at that disconnect, but I'm running a lithium battery and don't put it on a tender.
Old Feb 22, 2020 | 07:35 PM
Thanks you.
And how do you have the female USB fitting setup? ZIp tied to your bars somewhere?
Old Feb 22, 2020 | 07:44 PM
Yes, just a few zip ties to the small crossbar and it's nice and stable.
Old Feb 23, 2020 | 01:17 AM
GBAUTO's Avatar
Originally Posted by Kwak
I have waterproof cigarette lighter socket, connected directly to the battery, compact 2.4A charger, coiled USB power cable with angled USB phone connector and RAM mount phone holder base. Works fine.
Mine isn't waterproof but I use the same type of setup. Direct wired to the battery with a fused circuit. Works perfectly.
Old Feb 23, 2020 | 08:06 AM
philgoodklx's Avatar
Double USB and cigarette lighter (includes on/off switch to prevent battery drain) from ebay.
Got one on each bike. Excellent product and inexpensive.
Old Feb 23, 2020 | 07:52 PM
ozklx351's Avatar
When I connected my 2 usb ports they were direct to the battery, if the bike sat for 3 days it went flat. So I wired them to the headlight and not a drama since. I have one going to my handlebars and one to the saddle bags for charging other stuff like gopro batteries. Both are just zip tied where is convenient.
Old Feb 23, 2020 | 08:05 PM
https://www.ebay.co.uk/itm/182502536686
The on/off switch stops the battery from running down!
Old Feb 25, 2020 | 08:17 PM
Great stuff, guys. Thanks for the feedback. Definitely gives me some ideas.
Old Feb 26, 2020 | 07:27 PM
Gee, oddly enough that first one posted has a plug in for the battery that looks awful familiar - couldn't also be hooked up to a Battery Tender too, could it? (Rhetorical question)
