The people I work with.
Old Aug 15, 2011 | 04:21 PM
hehe..... the mountain bug catches another....
Does that help?
Old Aug 15, 2011 | 04:23 PM
Originally Posted by HeavyFuel
Sounds like you's overtired. The stock KLX will do fine in the mountains, it's got enough grunt to go anywhere you want to go; rider skillz and tires are the limiting factors.
I had no traction issues with a trackmaster rear and off highway front. 18lbs lbs of air also, had a handfull of flats up there, i dont know why people want to run 10lbs of air in the ROCKY mountains... pinch flats.
Old Aug 15, 2011 | 04:45 PM
Old Aug 15, 2011 | 05:51 PM
Blackheart58's Avatar
Pinch flats are one of the reasons I'm trying the Tubliss system. So far, so good in the desert, where rocks are abundant, sometimes hidden under a thin layer of sand, and oftentimes sharp. I do try to stay above 12 lbs of air, also.
Old Aug 15, 2011 | 06:29 PM
A guy with the tubliss system got a flat in our group. He had to get a tire plug kit from a jeep. held air the rest of the trip. Id recommend a tire plug kit on your bike.
Old Aug 15, 2011 | 08:02 PM
Yep...got it. It's a lot easier than carrying tubes!
Old Aug 16, 2011 | 06:21 AM
c_m_shooter's Avatar
The KLX will climb mountains. It gets a little weak above the timberline, but will still get you up and over anything if you are geared right and use a lot of clutch. I was in Colorado last week riding. I put the stock jets in with the airbox lid off and it was a little lean at base camp (7500 ft) . It smoothed out up the hill a little bit then got really weak like I said about the timberline. I was geared 14/47 and it seemed pretty good most of the time.
Old Aug 17, 2011 | 01:51 AM
treerat's Avatar
it was just a joke, i'm leaving the bike home..... Just was a funny mental pic to me.
Old Aug 17, 2011 | 12:27 PM
maninthesea's Avatar
Originally Posted by linkin5
Room air is only 1/5th O2 so you would not need to provide a total atmosphere just increase the amount of O2 available at altitude like a liter a minute or so to the airbox, so an E cylinder would last awhile at that rate but you'd be riding a potential bomb I'm afraid.
KLX250 consumes at a very conservitive estimate 250liters per min at idle.
air pressure and thus available oxygen at 2700ft is about 10% lower
at 6000ft its 20% lower.
So you will need an extra 5liters per min at 2700 & extra 10liters per min at 6000ft just to have same avaialbe oxygen at idle. At working speeds your looking at a lot of flow, Say 50-60liters.
That e cyl would last around 11-12min at best
But it would not really be a bomb. It takes a lot to make those tanks fail.
Old Aug 17, 2011 | 08:24 PM
RayTard's Avatar
Aren't we all riding a potential bomb anyway? Lol
CousinLarry
Jul 3, 2012 02:30 AM
lemac
Mar 22, 2006 09:47 AM
Shibby
Feb 9, 2006 02:05 PM
littledevil
Sep 27, 2005 05:41 AM
gotrice
Sep 13, 2005 09:06 PM
