Pair valve
Old Sep 13, 2018 | 09:46 PM
Kris250's Avatar
Default Pair valve
What’s the correct way to block off para valve in a 2018 fi? There is a connector going into it do you unplug the connector and take off all emission? Or leave everything on and unhook the rubber pipe and plug that off by it self. I was wondering if it would make the fuel injection like cut on if I undo the plug going to pair valve
Old Sep 15, 2018 | 01:32 AM
dp19's Avatar
You will need to keep the connector plugged in otherwise your FI light will turn on (try it). You need to block it off on the head where you took the pipe off.
Old Sep 15, 2018 | 02:30 AM
Kris250's Avatar
What about the hose? Block that too? May be a jumper wire on the pair valve connector to keep the FI light from coming on ?
Old Sep 15, 2018 | 02:37 AM
dp19's Avatar
You should find something to block the hose as well to avoid dirt getting into it. I'm not sure if you can trick the ecu by shorting out the wires, i just left mine plugged in.
Old Sep 15, 2018 | 11:07 AM
peabrain's Avatar
i made a ducttape plug on a screw i inserted in the hose as a blockoff, it is also remoable later
philgoodklx
Feb 24, 2025 01:24 PM
Thefirstzukman
Jun 30, 2018 09:34 PM
TomiKoo
Sep 10, 2012 10:33 AM
Raidmin
Jun 15, 2010 09:17 AM
CKawi
Jul 7, 2008 02:21 PM
