Pair valve
What’s the correct way to block off para valve in a 2018 fi? There is a connector going into it do you unplug the connector and take off all emission? Or leave everything on and unhook the rubber pipe and plug that off by it self. I was wondering if it would make the fuel injection like cut on if I undo the plug going to pair valve |
You will need to keep the connector plugged in otherwise your FI light will turn on (try it). You need to block it off on the head where you took the pipe off.
What about the hose? Block that too? May be a jumper wire on the pair valve connector to keep the FI light from coming on ? |
You should find something to block the hose as well to avoid dirt getting into it. I'm not sure if you can trick the ecu by shorting out the wires, i just left mine plugged in.
i made a ducttape plug on a screw i inserted in the hose as a blockoff, it is also remoable later
