Ok y'all. Bought an older KLX250
Old Jan 30, 2016 | 12:07 AM
  #31
roccitman's Avatar
Yeah, yeesh. I'm in Monterey, CA right now. But they probably won't let me carry it on.
Old Feb 27, 2016 | 02:30 AM
  #32
roccitman's Avatar
Originally Posted by klx678
If you want to know for sure, get a mechanic's stethoscope or long handle screwdriver. Put the tip on the tensioner, the cam cover in around the valves, around the clutch and listen (screwdriver handle against ear). If the noise is coming from the tensioner/cam drive that's the tensioner failed and chain slap as the tensioner gets pushed in leaving chain slack. If from the cam cover, valves need checked. This method is accurate enough you can tell which valve may be loose if it was valve ticking.
Don't know if there might be a Harbor Freight there, but a stethoscope is under $10 if there is. Not a bad thing to have hanging around when you need it, but not something you will use frequently.
Got a stethoscope and it *does* appear to be coming from the tensioner. Is this something that I need to replace asap and not ride on, or will it be ok to let it slap while I build up some money to buy a new one?
Last edited by roccitman; Feb 27, 2016 at 04:18 PM. Reason: fixed typo "doesn't" to "does"
Old Feb 27, 2016 | 01:21 PM
  #33
Originally Posted by roccitman
Got a stethoscope and it doesn't appear to be coming from the tensioner. Is this something that I need to replace asap and not ride on, or will it be ok to let it slap while I build up some money to buy a new one?
If you let it rev to the point where the rattle is and it's not from the tensioner, where is it from? Valves? Side panel rattle? Has to come from somewhere.
As for a tensioner, it can be ridden for a few thou without any concern, but worth doing as soon as possible, just because of possible wear. It is a cheap fix all considered. Since you are in the U.S. it is only a $42.80 expense. You see, I make and sell them. Any U.S. state or territory is that much since I use the flat rate priority small box. Out of the U.S. is quite expensive, $60.95 to Canada and $70.95 for the rest of the world. Still not high dollar compared to most stuff, especially considering it will never wear out and need replaced.
When it comes to the exhaust, if you can do it as carry on or checked I'd do that. The pipe could be wrapped with paper, but left open on the ends for inspection if they let you do carry on, or put in a suit case wrapped up and diagonally or in a gear bag for checking in the hold. I did do some numbers in USPS calculator for Hawaii and found that 30 lb in a 30" long 12" wide, 12" tall box is $67.60 priority and $55.78 parcel. Not horrible, but you could check it in a package on a flight for less.
Old Feb 27, 2016 | 04:17 PM
  #34
roccitman's Avatar
Oh man, I meant to say that it *does* seem to be the tensioner. The clicking was most clear in the stethoscope when I had it resting on the tensioner.
That's great, I'll get one. Can you recommend a good video tutorial for a non-mechanic?
Old Jun 20, 2016 | 04:00 PM
  #35
roccitman's Avatar
Originally Posted by deej
I just guestimated on the parcel size and weight, but it looks like USPS Ground is around $90.00 give or take $20.00 Yikes
Hey man. Spending some time in Oregon right now. You don't still have that stock exhaust do you? Is it really for a 2006?
Old Jun 20, 2016 | 06:34 PM
  #36
Yep hanging in my garage, still looks brand new.
Old Jun 20, 2016 | 06:59 PM
  #37
^ You're not the only one!
RobG
Aug 15, 2012 02:57 PM
kyrral
Nov 29, 2011 09:53 PM
c10
ZRX1200
19
Nov 22, 2007 11:40 PM
JB1
Dec 19, 2006 04:26 PM
KAWABUNGA
Jul 25, 2005 04:35 PM
