Ok y'all. Bought an older KLX250
Old Jan 18, 2016 | 10:02 AM
Originally Posted by roccitman
Yeah, the story I got was that he couldn't pass the safety check with the roached-out read shock. Here on Kauai no one cares about smog , but you gotta have everything working.
I noticed the top of the air filter is gone so they may have been doing some homebrew hot-rodding.
I replaced the seals on the forks. Tore the whole thing apart and cleaned it up. All the metal parts were in great condition, just dirty from torn up seals. In the next few months I'll tear it apart again and replace everything I can (have to build up the budget again).
Front brake seems sloppy, there's no way I could do a nose wheelie with the current state of the front brake. I replaced the pads and cleaned up the brake lines with fresh fluid. The front reservoir actually had dirt in it, never seen that before. I've seen some chatter about stainless line for the front, I might do that later too. I work on computers, not bikes so this is a learning mission.
I've also seen that people are replacing the CCT with one from that guy who makes adjustable ones (Krieger?). I don't hear any ticking from the top end so maybe don't worry about that?
Everything else is pretty bomber. The PO's son gave it a beating, I had to take a pipe and bend the bars back to straight. Choke it and it starts with two cranks. Idles nice, and seems to be able to run all day.
Thanks for the feedback!
-roccit
p.s. Any thoughts on my 13t front sprocket? Seems like a happy medium.
Two turns to start - rejetted.
On the tensioner no noise no problem. If you've read much here you may know the rattle usually shows up around 4000-6000 rpm. It is a progressive failure so there is no immediate problem when it does start rattling, so you have time if it does start. It takes a few thousand to get really loose to the point of wearing parts badly.
After playing around with all your mods and replenishing the "play fund" pick one up if you wish to be prepared.
Old Jan 18, 2016 | 11:31 AM
surferdude's Avatar
Nice bike. How much did you purchase it for?
Old Jan 18, 2016 | 12:40 PM
dpippin's Avatar
I don't have the lid, it's just gone. Don't suppose anyone has an extra KDX200 lid
I don't worry too much about the 13t at higher speeds. I live on Kauai and the fastest speed is 50mph (80kph). Great suggestion for the overflow tank, thanks!
I wouldn't worry too much about the lid for the air box.
A lot of people including myself leave it off for more air flow
It will be noticeably louder however.
If you want a lid you need the KLX250 lid
The reference to a KDX200 is the snorkle only not the lid
SS brake lines do not increase brake power. They just give it a better feel because the SS lines don't swell like the rubber lines do.
If you replace the front fork springs the front end dive etc will be greatly improved.
Old Jan 18, 2016 | 04:00 PM
roccitman's Avatar
Roger that! And thanks for the advice on the cam chain tensioner!
Old Jan 18, 2016 | 04:01 PM
roccitman's Avatar
$700 USD. And he threw in a helmet
Old Jan 18, 2016 | 05:07 PM
roccitman's Avatar
Ok thanks. I won't stress about the airbox lid. We have Na Ali'i Harley Davidson club in my neighborhood so noise isn't really a concern
Good tip about the brake line, I'll just deal with it. Might try to source some stiffer springs for the front though. Thanks again.
-r
Old Jan 24, 2016 | 12:39 AM
roccitman's Avatar
Ok, give this a listen (sorry it's blurry, you're not going blind):
http://d.pr/v/1jwTB
Does that sounds like tensioner? I've been thinking it was the heat shield thingy on the pipe.
Last edited by roccitman; Jan 24, 2016 at 12:49 AM. Reason: Oops, wrong link. Fixed.
Old Jan 24, 2016 | 04:07 AM
MaverickAus's Avatar
Is the heat shield loose? 1st place to look
Old Jan 24, 2016 | 04:22 AM
roccitman's Avatar
This one?
I replaced the screw that's missing. That's what I thought it was. Still rattling though. Maybe take it off clean it up and snug it back on?
Old Jan 24, 2016 | 07:08 AM
Yes, that one. If there is crap in the threads (common) the screws may be tight but not holding the shield in place therefore rattling. Take them all out clean the threads and (red) locktite the screws in and replace the missing one. That eliminates 1 possible source of a rattle. Make sure nothing else is loose.
