Oil leak from gas tank securing bolt?
Old Jun 19, 2018 | 12:01 AM
Dragon351's Avatar
Default Oil leak from gas tank securing bolt?
This makes no sense. Where could this oil be coming from?
Old Jun 19, 2018 | 10:56 AM
s10gto's Avatar
I don't see any grommet left? The rust under the bolt is a sign of the tank moving. My guess is that's fuel possibly dissolving what's left of the rubber. Tank is most likely cracked.
Old Jun 19, 2018 | 11:03 AM
Dragon351's Avatar
Thanks.
That’s not good.
It smells and feels like oil, not like gas.
damn.
Old Jun 19, 2018 | 02:56 PM
s10gto's Avatar
Look at it this way....Now you can get the IMS tank. After all Safety first!
Old Jun 19, 2018 | 03:03 PM
"looks" like oil to me. I tried to smell it, by my allergies this morning just aren't helping.
I suggest you clean everything off very well, then inspect carefully after your next ride and see where this is coming from. It's not normal. S10 may be right on a cracked fuel tank, but why doesn't it smell like fuel?
And yes, your fuel tank bolt should have the appropriate collar, damper, grommet, gasket, washer, wicket or whatever the thingamajig is called.
Old Jun 19, 2018 | 04:35 PM
Dragon351's Avatar
This morning, it smelled like gas. He’s right. The pic from Partzilla’s schematic
is the part I need.
Old Jun 19, 2018 | 05:39 PM
Dragon351's Avatar
And probably 9215A as well
Old Jun 20, 2018 | 12:44 AM
RaceGass's Avatar
You’ve got a 09 frame/gas tank mounts, the microfiche shows the later frame with bolt in isolated gas tank mounts. The rubber bushing is missing it looks like also. The tank looks almost mounted solidly. I’d pressure check that tank
Old Jul 2, 2018 | 01:24 PM
Dragon351's Avatar
For the knowledge base:
The dampener for the gas tank doesn’t seem to exist, at any distributor. Because it appeared to be similar in the “microfiche” schematic, I ordered “damper, head lamp, 92075-1123” and it fit perfectly.
LKN250s
Feb 14, 2019 10:15 PM
Dragon351
Jun 25, 2018 05:12 AM
Dragon351
May 28, 2018 01:58 PM
knjjjr
Feb 17, 2008 07:41 PM
k9jms
Feb 13, 2007 04:15 AM
