oil change
Old 09-20-2009, 06:50 PM
bmx_lar's Avatar
Default oil change
so ive been doing some research about these oil filters. some say that the '09 takes a different filter, but the dealer says the 09 and pre 09 are the same.
kawasaki-52010-1053
fram-CH6015
wix-24944
As for oil, i've decided to go with lucas semi-synthetic 10w-40 High Performance motorcycle oil.
Old 09-20-2009, 08:37 PM
Dready's Avatar
I just did my 1st oil change today at 75 Miles!
Advance Auto Parts has the filter ...its $5.79 part # CH6015
And i got 2 qts of Valvoline 10w-40 for $4.39 qt
Be careful with the spring behind the filter..it was the hardest part for me!
Old 09-20-2009, 10:36 PM
Bend the spring open a little on one end ( make it a little larger in diameter ). Doing that will make the spring tight where it locates in the bike, and it will stay where it's supposed to.
Dan
Old 09-20-2009, 10:54 PM
Dready's Avatar
So make it wider on one end and then place it inside the bike 1st..then put the filter in?
Old 09-20-2009, 11:33 PM
lcpl0331's Avatar
yes that's it. When you make one end open a bit further you can sorta wedge it in between those 3 bumps on the inside of the oil filter housing. I usually have to spin the spring a bit to get it to stay in place.
Old 09-20-2009, 11:42 PM
yup, so much easier that way.
Old 09-21-2009, 12:07 AM
Dready's Avatar
Cool thanks
Old 09-21-2009, 12:16 AM
dmar's Avatar
I just lay the bike on its side and put the filter, spring and cover on.
Old 09-21-2009, 12:34 AM
Fourty2ri's Avatar
You did get motorcycle oil, right?
Old 09-21-2009, 12:39 AM
Dready's Avatar
yes...wet clutch approved!
Quick Reply: oil change
