oil change
so ive been doing some research about these oil filters. some say that the '09 takes a different filter, but the dealer says the 09 and pre 09 are the same.
kawasaki-52010-1053 fram-CH6015 wix-24944 As for oil, i've decided to go with lucas semi-synthetic 10w-40 High Performance motorcycle oil. |
I just did my 1st oil change today at 75 Miles!
Advance Auto Parts has the filter ...its $5.79 part # CH6015 And i got 2 qts of Valvoline 10w-40 for $4.39 qt Be careful with the spring behind the filter..it was the hardest part for me! |
Bend the spring open a little on one end ( make it a little larger in diameter ). Doing that will make the spring tight where it locates in the bike, and it will stay where it's supposed to.
Dan |
So make it wider on one end and then place it inside the bike 1st..then put the filter in?
yes that's it. When you make one end open a bit further you can sorta wedge it in between those 3 bumps on the inside of the oil filter housing. I usually have to spin the spring a bit to get it to stay in place.
Originally Posted by Dready
(Post 394377)
Cool thanks
I just lay the bike on its side and put the filter, spring and cover on.
(Post 394370)
yes...wet clutch approved!
