Noisy top end
Old Apr 24, 2008 | 06:43 AM
matt2496's Avatar
Default Noisy top end
Ok for the last 3,000 miles or so I've had a tap in the top end on my KLX250. Its only there from 5,000-6,000 RPMs. It is most noticeable at 5500 RPMs. When this intially happened I checked the valve clearance and the timing chain tension both are good. I then checked the ACR spring. It seems a bit weak IMO. Does that spring wear out at 2,000 miles?
Does anyone else have a similar noise in that RPM range?
Old Apr 24, 2008 | 09:32 AM
Default RE: Noisy top end
not even gonna get into it.... but im guessing its the acr... mine had a noise at just under 5000 rpms....
Old Apr 25, 2008 | 01:39 AM
LearjetMinako's Avatar
I doubt it could be the ACR. The mechanism is simple. You might want to check the timing chain. I have a similar issue. Just be adding tension to thetiming chain makes the noise go away.
Byrdjo
Jul 3, 2015 09:21 PM
funny150
Aug 12, 2011 04:46 AM
redixson
Feb 18, 2009 02:44 AM
mycat8urskidoo
Ninja 500R
Apr 4, 2007 09:31 AM
