New Rear Brake Rotor Needed
Old Feb 1, 2023 | 05:58 AM
MXM's Avatar
MXM
Default New Rear Brake Rotor Needed
As per the title, a new rear brake rotor is required for my 2018 KLX250s. Where can I buy from online? Cannot find anything online after some searching.
Thanks.
Old Feb 1, 2023 | 12:20 PM
If you can find a pre-2009 rear rotor and the caliper carrier you can use it. The carrier for the 2009 and later is for the 240mm rotor, the pre-2009 carrier is for the 220mm rotor. I wanted the weaker rear braking power so it was less likely to lock up and would have more feel. Those rotors may be more common there.
There is a late model petal cut rotor on ebay right now for $27.95, no idea what shipping would cost, but it shouldn't be that bad, It might fit in a USPS flat rate envelope and ship for around $40. Might be less by just using a plain envelope. No idea what it might cost otherwise. Either way that's probably cheaper than doing a new one.
Trailrider3428
Jun 21, 2022 08:54 PM
prakthad
Feb 6, 2019 07:44 PM
andyng
Feb 9, 2018 02:18 PM
klx678
Jan 30, 2014 10:01 PM
JeffZX11
Jun 16, 2008 11:38 AM
