New Rear Brake Rotor Needed
As per the title, a new rear brake rotor is required for my 2018 KLX250s. Where can I buy from online? Cannot find anything online after some searching.
Thanks. |
If you can find a pre-2009 rear rotor and the caliper carrier you can use it. The carrier for the 2009 and later is for the 240mm rotor, the pre-2009 carrier is for the 220mm rotor. I wanted the weaker rear braking power so it was less likely to lock up and would have more feel. Those rotors may be more common there.
There is a late model petal cut rotor on ebay right now for $27.95, no idea what shipping would cost, but it shouldn't be that bad, It might fit in a USPS flat rate envelope and ship for around $40. Might be less by just using a plain envelope. No idea what it might cost otherwise. Either way that's probably cheaper than doing a new one. |
