New Maier MX rear fender...
Old Nov 2, 2007 | 02:28 PM
  #41
tremor38's Avatar
Default RE: New Maier MX rear fender...
Yeah I'm sure you know all of that and I'm not trying to imply that you don't. Mysoap box was for whomever might benefit from it. In retrospect, I shouldn't havemadethat small piece of your mosaic look like the center piece of my argument...or that I was trying teach youanything Itjust spurred thought and I wrote[8D]
+1 on the lithium batteries. I've known about that problem since the mid-eighties when they put big warnings in our operating manuals about rescue sonobuoys with lithium batteries. It's kind of scary to see those li-polymer batts burst into flames because they have been touted as 'safe' compared toother designs oflithium batteries. Many of them also advertise having 'overcharge protection circuits,' but now I'm wondering just how effective those are.
ORIGINAL: Nobrakes
My only objective here was to point out the dangers of Li-Ion or Li-Poly batteries. I guess I'm not really recommending any particular course of action, just that I would steer clear of Lithium batteries as a replacement for lead-acid. And if the weight was really important to me, I would just remove the battery and starter altogether and use a kickstarter. There may be additional things you need to do for that conversion. That kind've goes without saying, or so I thought.
Old Nov 2, 2007 | 03:01 PM
  #42
ORIGINAL: tremor38
I'm sure they are very safe ... until they fail. A motorcycle stator is a very noisy and harsh electrical source and even with a lot of regulation, there are damaging spikes and other EM phenomena. I wouldn't trust anything but a military grade charger in an environment like that.
Even with the latest cell-phone technology and their very low current batteries you still hear of problems such as the batteries exploding in people's pockets giving them bad burns. Same with laptops. And those are arguably supplied with ultra-clean charging circuits and not exposed to the elements and harsh environment that a motorcycle is. The price of a component failure is just too high for me. That's just not something I'd ever want to worry about on my bike.
Old Nov 2, 2007 | 04:14 PM
  #43
tremor38's Avatar
ORIGINAL: Nobrakes
Yes, and the reason our reg/rectifier isn't very big is that it relies on our the battery to smooth out a lot of that vice incorporating large capacitors. A lead acid batt can handle that just fine but I'll bet the solid state components of that over charge protection wouldn't..and as soon as they fail, watch out. Could you imagine your battery compartment suddenly busting into flames? []
Old Nov 2, 2007 | 04:37 PM
  #44
tremor38's Avatar
One more notefor those people thinking of going to a purely kick start system. If you're going to be kicking it all the time to getthe bike started,that opens-up another can of worms.The KLX300 hasa problem with a failing idlegear upuntil a certain year when they changed the ACR timing to make it easier to kick, thus putting less pressureon theidle gear.Before they changeddecompression timing, the off- center brass bearing on the idlegearwould become cone shaped with use and the uneven wear would cause the gearto fail, often causing extensive damage to the engine due to metal fragments from the gear becoming lodged in places they weren't supposed to be.
The KLX250S still uses the old exhaust cam part number (old ACR timing) because the idle gear is a non-issue with e-start, so if you are consideringgoing to a full-time kick start set-up, a good way to head-off trouble is by going to a later model KLX300 exhaust cam (expensive route)or send your exhaust cam to a fellow named Brewster at Thumpertalk (inexpensive route). He has done the ACR timing mod to numerous KLX300's. It involves pressing the ACR off of the exhaust cam, then pressing it back on in a slightly different position. The actual procedure is posted at PlanetKLX..but you need the right tools to get'er done.
jhoffy22
Jul 6, 2011 02:54 AM
GETRAD
Mar 24, 2009 07:40 PM
KLXer
Nov 24, 2008 11:53 PM
KLXer
May 12, 2008 12:43 AM
droflet
Jul 12, 2006 02:29 PM
