New Dyno Results
Old Oct 19, 2018 | 06:18 PM
Graham Newell's Avatar
Default New Dyno Results
Hi all,
I finally got around to getting my 2009 FI model on the dyno. Nothing special done really, normal stuff. The biggest difference after the cam mod came from the Dobeck EJK, tuned right this really makes my bike ridable.
21.85 hp at the rear wheel (25.7), and 22.16 nm at the rear wheel (26.08). Not sure how that rates, but I'm gonna leave it at that,
Old Oct 19, 2018 | 10:05 PM
Tacoma660's Avatar
where di you find the green engine plugs?
Old Oct 20, 2018 | 12:10 AM
Klxster's Avatar
The fueling curve needs to stay below the red 13:1 line at all times during WOT ... Ideally between 12.5 and 12.8 for the entire operating range ( @ WOT)..
Lots of power to be found if you can get your bike fueled correctly..
Old Oct 20, 2018 | 12:19 AM
Kris250's Avatar
So this is the tune with ejk?
Old Oct 20, 2018 | 02:10 AM
durielk's Avatar
Does a knobby tire alter the dyno ? I would imagine it would be a big difference, or quite a few pts.
Old Oct 20, 2018 | 02:36 AM
Klxster's Avatar
I don't know about his bikes' tires, but aggressive knobby tires do not work well with the dyno drum..
His european dyno run does not provide us with much usable info about power production- it is not even an engine RPM chart. The AFR chart does tell us data we can use..
Old Oct 20, 2018 | 10:18 AM
peabrain's Avatar
i wish i had the time and extra cash to put mine on a dyno since i am using a powercommander just to sort of compare the 2
Old Oct 20, 2018 | 02:05 PM
Default Other dyno chart
Thanks KLXster, other dyno chart attached.
Can't remember the EJK settings but I will check when I get the chance, bike is in storage now. Maybe I need to tweak it to get stoichiometry right.
I put Siracs on for the dynoing, worked fine.
Klxster
Oct 7, 2016 04:08 PM
Klxster
Jun 28, 2014 02:32 AM
Nikolaj Lykke
May 4, 2014 11:04 AM
TMAN
Jul 2, 2007 04:19 AM
Marty
Dec 17, 2006 12:47 AM
