New Chain / Sprocket combo observation / ?
Old Jun 16, 2021 | 01:13 PM
Neanderthal's Avatar
Default New Chain / Sprocket combo observation / ?
Just a quick observation and question (bike is a USA 2018 FI model - no performance mods - Dunlop D605 tires still on).
I installed a 45t rear sprocket and 108-link chain this past weekend (still using the 14t front). I weigh approx 180 with gear, and running wide-open throttle on a level highway, I am seeing about 8,500 rpm's with a gps-verified top speed of 72.3 mph. From what information I can find, does this sound about spot-on performance-wise for this bike?
Old Jun 16, 2021 | 04:11 PM
Yes, horsepower maxes out at around 8600 rpm My gearing chart for the 2009 up shows 75.52 at 8600 rpm with an actual tire diameter of 25.3 If you would like a copy of the spreadsheet I have attached the .xls file.
Old Jun 16, 2021 | 04:35 PM
Thanks! I took a quick look at your spreadsheet, looks like I'm really close. Looking forward to some off-road riding with this new combo (14/45), I was pleasantly surprised with just trying the 13/42 combo. I found the 14/42 OEM combo had me prone to stalling a lot when crawling up hill.
Old Jun 16, 2021 | 07:55 PM
14/45 is nearly the same as the 13/42, thing is it will cause less wear, because the loads are spread over more teeth. Nice part too is the ability to go higher with a 15 or lower with a 13 if needed. I used that sheet to compare tire sizes when looking to have a set of roll in SM wheels for my KLX650, The variables are the tire size the sprocket sizes, and the rpm. You can see what speeds are at a set rpm in any gear with whatever tires. I pulled the tooth count from Kawasaki's parts schematics, then set up the calculating cells to do the numbers. download or copy the file if you have a new enough version of Excel.
philgoodklx
Aug 20, 2019 04:07 PM
mtbcrossover
May 21, 2013 03:32 PM
kawiridr04
Mar 22, 2007 05:25 PM
ktn
Oct 27, 2006 08:39 PM
Olympia636
Sep 20, 2006 09:49 AM
