new carb or exhaust on top of 351
Old Mar 2, 2014 | 12:13 AM
RockabillSlapMatt's Avatar
Originally Posted by Richard Avatar
That's where the 40mm carb comes into play? I'll find out because mine will be here in a couple months.
This TM36 is doing so well on my 250, the additional 80cc should easily be up to a 4mm larger carb bore. Especially with an accelerator pump to counter low any inherent low speed speed lag.
Luckily the cam mod is easy to do and undo if I just take the spring off the ACR.
Someone here used Webcams and didn't notice much of an improvement-he said it'd kind of be the last thing to do after all other mods were exhausted
Supersonic nozzle
I'm excited for your results on the 40mm carb! I wonder how they didn't notice an improvement. It's like having a stock small block and install a performance cam from edelbrock, you get more of a lope and the power band changes (typically more high end performance)
wildcard, I agree it's hard to believe a smaller header pipe can give more performance over a better breathing header for a performance engine. If you were to have head work, very aggressive cams, then I would tend to agree that a header is needed to maximize the power. However, if you just do the big bore kit, the valves are still the same size, the cams are the same grind, and some people (sadly me even though I want one) can't justify the cost of a header($250?) compared to a pumper carb(tm36 $300) since the power gained from the header will be minimal if any at all on just a big bore kit alone.
Old Mar 2, 2014 | 12:33 AM
wildcard's Avatar
Just because the valves are still the same size doesn't mean theres not more exhaust volume with a BB kit. If there weren't their would not be any power increase.
A header is about $150 (115 if you go with a knock off).
Each his own like I said.
Old Mar 2, 2014 | 08:04 PM
only $150? I stand corrected, I'd try it for $150 bucks.
Old Mar 2, 2014 | 09:24 PM
Klxster's Avatar
Hey Matt, looks like the mega bomb can be had for as little as $219 w free shipping.
FMF MEGABOMB HEADER SS KAWASAKI KLX250S 2012-2013 - Discount Moto Direct
Old Mar 2, 2014 | 09:31 PM
AGH! don't temp me! Do you now if the headers only work with fmf pipes, or all klx250s slip ons?
Old Mar 2, 2014 | 09:35 PM
Klxster's Avatar
Aw crap.. I guess Im not sure about fitment with our DG-R's...
Old Mar 2, 2014 | 09:38 PM
Klxster's Avatar
Straight from FMF website....
Can I run one of your headers with my stock muffler?
Our headers, whether it be the PowerBomb or the MegaBomb, are fitted to match an FMF series muffler. We do not recommend or guarantee you try to match it to a stock muffler..
Old Mar 2, 2014 | 09:40 PM
  #28
Klxster's Avatar
More from FMF - Rider Support - FAQ - FMF Racing
How much power will I gain using FMF products and will I notice a difference?
If your definition of power gains is, substantially increasing horsepower & torque, rate of acceleration, and the important fun factor, then yes you will gain lots.
Generally you'll see a 5%-20% increase over stock depending on your application, but like jetting there are many variables to contend with. Don doesn't put in countless hours of R&D time and lost sleep into a product to not have it perform like the way he feels it should.
We've been around long enough, that you can trust that any time you install an FMF exhaust product, you will definitely " FEEL THE POWER ".
Old Mar 2, 2014 | 09:48 PM
  #29
Klxster's Avatar
Alright Matt.. I just bought one for $219... I'll be back home sometime in the next month and I'll do us all up a dyno before and after.
Old Mar 2, 2014 | 11:06 PM
  #30
You da man! I look forward to the results!
