New bars with risers
Old 10-27-2011, 12:49 AM
BleednGreen68's Avatar
Would I need longer cables if I just replace my handlebars? Or is that only if I added risers?
Old 10-27-2011, 04:35 AM
Originally Posted by LikesToThump
I was referring to Tusk High bends without the 1 in risers... sry I didn't make that more clear.
I want a high bend for sure, but I also want red bars lol, and only the highbends come in red by convenience for myself :-P I'm also debating the tusk hand guards as well, I think ill just end up cutting the levers down if needed; seeing how there ground up on the ends already.
also rob, you need to trim that kawi mullet man, I wish I had my bike up here, so I could take a pic of how I trimmed mine; turned out good.
I used Tusk CR mid bend, with 1' risers. The Tusk CR High bend is only 1/4" taller (3.5" vs 3.75"). Should fit with stock cables IMO. Also, using the Tusk hand guards and am pleased. Levers cut, cleaned, and finished with shrink tube.
Old 10-31-2011, 04:15 PM
cegusman's Avatar
Got the bars mounted. Had to reroute the throttle cables and reposition the front brake hose bracket. for them to work. Clutch cable was a no go. No way in hell it would reach. Ordered an 3" extend one from Motion Pro for $40 should be here some time next week. May do the throttle cables in the future also, they are only $35 each.
I will get some pics when I get everything put back together.
Old 10-31-2011, 09:38 PM
dan151's Avatar
I put Pastrana FMX pro taper bars (4.75" tall) with Tusk Big bar clamps (0.75" tall) on my 07' S and all cables reached fine.
seems to be that the 06' and 07' S models have longer cables and the 08' and up SF have shorter
Diamond Jim
04-13-2013 06:04 PM
radiobob
Ninja 650R
01-21-2013 07:26 AM
JFlame
10-21-2011 02:54 PM
paulibiker
10-12-2005 07:09 PM
Quick Reply: New bars with risers
