New AGM battery makes starting a breeze.
Old 11-30-2011, 06:00 PM
ol'klx-er's Avatar
From the page that LikesToThump linked:
"AGM is the preferred battery for upscale motorcycles."
Makes me feel even better about having bought the KLX.
Last edited by ol'klx-er; 11-30-2011 at 09:31 PM. Reason: terrible typing, fat fingers
Old 11-30-2011, 07:25 PM
wildcard's Avatar
Originally Posted by zomby woof
My $40 Li battery is still going strong.
I'm definately going to be getting a couple of those, one for the KLX and one for my upcoming track bike.
Old 11-30-2011, 09:17 PM
zomby woof's Avatar
Originally Posted by LikesToThump
I don't trust lithium, I've been reading into batteries immensely lately... due to both curiousity brought on by multiple people debating AGM vs SLA on this forum, and simple needs for smart battery replacement for projects. I'm not saying its bad... I just don't see it benifitting the motorcycle communitty a whole lot... its life cycles aren't amazing enough to me to justify 3x price increase.
I do however see a noticible gain in the use of AGM...
Here is a link to a extensive website with good info on almost any battery derivative you could ever ponder.
Absorbent Glass Mat (AGM) Battery Information - Battery University
At $40, my Li battery is cheaper, lighter by bout 90%, and just as powerful as the stock battery. I don't see a down side. There are millions of Lithium ion batteries in service right now in power tools. They've pretty much made everything else obsolete.
Old 11-30-2011, 10:27 PM
CousinLarry's Avatar
Lithium Ion batteries are the shiz-niz.
Where'd you get the one for $40? I was thinkng about making a pack from some RC lithiums I have, and put jumper cables on it as a sort of in the backpack jump-starter if needed.. I have some good size lithium packs from my RC helos and airplanes..
Old 11-30-2011, 11:39 PM
BleednGreen68's Avatar
If you take care of your battery, it should last you along time. I got over 5yrs out of my original 05 brute force battery. Finally replaced it. Does optima makes small bike batteries? I know the car/truck batteries seem to be really good.
Old 12-01-2011, 12:03 AM
zomby woof's Avatar
If you make your own, the A123 cells are the ones to use.
I use this exact battery in my KLX. It works flawlessly
4S1P 13.2V2300mah A123 original Battery for RC hobby | eBay
Same as the expensive ones. If you ask, he'll put larger cables on, but the original cables have worked fine for me.
I use this one in my car
A123 battery 4s3p 13.2V6.9AH motorcycle start battery | eBay
Old 12-01-2011, 02:05 AM
LikesToThump's Avatar
I said at 3x the price... You basically made your battery, I'm not sure exactly what type of lithium batteries those are so I can't really say much about what you got in your bike... I Said their fine batteries, at 40 dollars I would run it as well.
The point is they aren't the best choice for a bike... great their lighter.
However, their incredibly sensitive to heat and overcharge, and while they have excellent deep cycle abilities they are not good for pulse current.
The fact is the main killer of SLA batteries is sulfation... anything below 80% charge on a lead acid battery is causing sulfate to form, let your battery run dead and leave it dead for more than a week and its gone forever... almost 0% chance of recovery, you'll have to drain the cells and acid wash them and start with fresh acid to bring them back.
Keeping your battery charged and maintained along with casually putting your lead battery on a desulfator till you get a peak voltage reading again, can extend the life of a typical SLA battery to 10 years easily.
  #28
Old 12-01-2011, 01:06 PM
KE100's Avatar
The issue I would be most concerned with regarding a Li ion battery in my bike is the charging. The charging circuit in these bikes are relatively "dumb" and are set up to charge lead acid type batteries. Li ion batteries must be handled carefully when charging as overcharging/heating can lead to serious problems. That's why they don't sell rechargeable Li ion batteries in normal "D" "C" "AA" and "AAA" sizes. They can be dangerous if charged in a non Li ion charger. So these batteries have proprietary packaging and charging adapters to avoid mishaps.
Does anyone have any information on how the charging system on the KLX works? Is it demand based? Does it vary the current being sent to the battery depending on charge level? Does it trickle charge when the battery is full?
  #29
Old 12-01-2011, 01:34 PM
zomby woof's Avatar
I said at 3x the price... You basically made your battery, I'm not sure exactly what type of lithium batteries those are so I can't really say much about what you got in your bike... I Said their fine batteries, at 40 dollars I would run it as well. .
How did I basically make it? I bought it, and connected the wires.
You guys run whatever you want, I don't care, but don't make things up to try and prove that whatever you have is best.
For performance, price, and weight, nothing you have presented can touch these batteries. They just plain work, and kick ***. I have them in my bike, and daily driver performance car, so if they didn't, I would know by now.
  #30
Old 12-01-2011, 02:14 PM
Blackheart58's Avatar
You guys run whatever you want....
Our local quasi motorcycle club has been turned on to Lithium batteries, and they're the most common battery chosen when a new one is needed. Some that stress about weight savings are choosing them even if they don't need a new battery. One of my three bikes has a Lithium (the KLX), and my other two will be Lithium when they need to be replaced. No more trickle-charging for me.
Quick Reply: New AGM battery makes starting a breeze.
