Neutral Light problem
Old Feb 22, 2008 | 02:13 PM
Kohburn's Avatar
Default RE: Neutral Light problem
the actual neutral sensor would be my guess - could be the sensor or could be a bad connection somewhere - i'd recommend taking all the connections off (one at a time) then clean em and put em back together with dielectric grease (keeps water out and corrosion away)
Old Feb 22, 2008 | 02:57 PM
ORIGINAL: EMS_0525
they will if you bypass the clutch sensor... like he did.... i have seen people do that..... hit the starter with it in gear lol... its funny...
I could see that coming in handy in certain situations on the trails.
Old Feb 22, 2008 | 03:02 PM
Truckman's Avatar
The sensor is down by the front sprocket in the side of the engine case.
Yes they will start in gear.I had my bike against a tree in my front yard while doing maintenance and a few cold ones and hit the start button and fired her right off the tree with a nice kerplunk of falling right onto it's side after it cleared the tree...LOL it's the only time i ever did it....
Old Feb 22, 2008 | 03:07 PM
my old ninja had that switch broke and watched it launch off the kickstand a couple of times[&:]
Old Feb 22, 2008 | 05:41 PM
pie4foou's Avatar
i was having problems with the light even before i bypassed the switches (kick start, and clutch) its came on today for a little bit, but i think that your right, the connection is probably full of water and mud (as it should be) so i think its due for a good scraping/cleaning/greasing... i'll be sure to let you know if it fixes the problem.
Old Feb 23, 2008 | 06:06 AM
neilaction's Avatar
Pull the wire off the actuator which is down near the front sprocket.
Touch this wire to earth (any metal part of the engine or frame)
if the neutral light comes on when this wire is grounded then the actuator is faulty.
This only takes a second to do.
Mucky_Waters
Mar 23, 2015 10:19 PM
Mcnutts
May 28, 2011 03:23 PM
ziggy90
Aug 9, 2010 01:45 PM
fLiPsYde
Jan 27, 2009 06:12 AM
jimbo59153
Ninja ZX-9R
Jun 29, 2007 11:30 PM
