Need help with seal savers
Old Oct 12, 2007 | 09:39 PM
sinkoman's Avatar
Default Need help with seal savers
I have a set of velcro on seal savers from DirtSkins, and I can't seem to get them to fit. They'll go over the fork just fine, but the plastic fork guard guide that clamps down onto the outer tube just doesn't want to bolt down once the seal savers are on.
So, in my frustration, I thought that maybe cutting off all the velcro would help get the seal savers to fit. Nope (stupid idea, I know). Now i'm stuck with a set of seal savers that have degenerated into strips of neoprene.
So now I need to figure out how to get these strips of neoprene to stay onto my forks. Ideas?
Old Oct 12, 2007 | 09:49 PM
Default RE: Need help with seal savers
my seal savers on my husky were zip tied on real tight.
Old Oct 13, 2007 | 12:22 AM
Shadetree's Avatar
I haven't tried the velro Seal Savers, but I have the kind you have to pull the forks to install. Mine barely work beneath the fork guard clamp, but it's do-able. I had to have one of my sons squeeze the clamp with large pliers so I could start the bolts. All went fine after that. My guess is that the velcro Seal Savers are a little bulkier than the ones I have. If you can get some help, try squeezing the clamp as mentioned while you fit the bolts into the threads. Or, yo could purchase slightly longer bolts for one hole and once it's partially threaded in, put the stockers in the other hole to smash it all down. Just be careful not to break the clamp.
Old Oct 13, 2007 | 09:56 PM
vurtle's Avatar
I use the velcro seal savers and I just left the fork guard guides off. No problems since.
Old Oct 14, 2007 | 09:16 AM
sinkoman's Avatar
Well, I ended up just cutting the velcro off of both of them, and then using zipties to keep them on.
Yes, I can relate. I spent at least a half hour trying to get the bolts on the fork guard guides started!.
Back Trailin
Jun 28, 2008 01:30 AM
Flood_33
Apr 28, 2008 04:08 PM
Nobrakes
Nov 15, 2006 05:20 PM
ZX12Rider
Ninja 500R
Jun 15, 2005 07:24 PM
okie
Apr 10, 2005 11:32 AM
