My mods!
Old Jul 24, 2008 | 02:19 AM
Kawi Wawi's Avatar
illenium, I would put in the 132 mainjet if I were you.
Hey - anyone notice in that PDF for the new Dynojet kit, that:
a) the 250S kit has a lot more mainjets included than the 300 kit
b) the part number on the drill bit is DD 5/32 - 5/32nds? Wasn't it 7/64th's in the 300 kit?
c) the needle is different than the 300 kit
d) it includes a new slide spring (I wonder what the difference is? I actually cut my stock slide spring by 3/4" because I'd heard it improves throttle response.)
Old Jul 24, 2008 | 07:09 PM
ryathis's Avatar
I just ordered the dyno jet kit for the 2009 klx250s SKU # 2152. I get it on monday Id be happy to answer any questions about it on tuesday after its installed kawi Wawi regarding throttle response or anything else
Old Jul 25, 2008 | 03:36 AM
illenium's Avatar
hi, thanks for the tip, i'll try the 128 first with needle on 4rd clip
2 1/2 turns out, seems to be standard setting of some others and
than go up if neccessary
my klx300 dyno
a) 124 - 132
b) nope, same, its a dd 32 and 5/32
c) needle is dno352
d) no springslide included
greetz
Old Jul 25, 2008 | 04:41 AM
Originally Posted by deej
Mine is the dynojet kit for the 300. 132 and 40 with no lid, full Muzzy and I don't really know the other tweaks on the carb since I didn't do the work. All I know is 8000+ miles and its never given me a bit of trouble.
A Bike that is jetted a little rich always starts and runs....the lean ones got the power...just sayin.
btw a 130 with 38 pilot would probably be better for a 250 sleeve.....BUUUUUUT I never tried a dyno needle before.
Old Jul 25, 2008 | 04:51 AM
KAWASAKIspeed's Avatar
the carbs on the two bikes are a little different.
Old Aug 2, 2008 | 11:53 AM
The frog's Avatar
My mods are done, the bike runs great and I can feel it on the seat. Very happy of the mods and thank you guys for your help. My next post will be a comparison on the road and in the trails between a moded KLX and a stock WR. One of my friends just bought a brand new one. C'ant wait to try it...
see ya!
Old Aug 2, 2008 | 06:51 PM
RaceGass's Avatar
the 5/32 drill bit is to drill a hole in the a/f screw plug. To remove the plug so you can adjust the a/f mixture, in kit 2206 your provided a pan head screw to thread into to pry it out with.
Old Aug 6, 2008 | 12:53 AM
2001KLX300R's Avatar
Default Hey, Deej
Just curious what size front and rear sprockets are you running and whats your top speed with them ?
Old Aug 6, 2008 | 01:35 AM
je2000's Avatar
Also, is your airbox loud with no lid? I heard it was with no lid...And that people are getting lousy results with no lid since some kind of vacuum suction is what the carb needs...
From the supermotojunkie forums
"The KDX snorkel has about 10 times (unscientific) the hole than the stock KLX one does. Several people have tried the "no lid" approach with lousy results. Either they can't get the jetting right, or the intake noise is too much for them. I'm sure the airbox is nothing like the KDX airbox. The KLX is a four stroke and the KDX is a 2 stroke. The KLX uses a CV type carb which needs a bit of airbox vacuum to work properly. Velocity stacks, pod filters and open airboxes just don't work well with these carbs. The KDX is a WAAAY different animal. The reason the KDX snorkel works well here, is that is fits in the stock place, is fairly quiet, and flows lots more air. I haven't done mine yet, but the others on the links I listed above (lots of KLX owners) have done all the research for us..."
Old Aug 6, 2008 | 03:09 AM
I took my lid off of my KLX300 and it runs alot better I think. The sound from it doesnt bother me, it's just the sound of more power.
