Is my jetting right?
Old Nov 15, 2012 | 05:18 AM
Originally Posted by Warren3000
Damn it! I already paid for it online what about all the talk about the stock needle being no good? Whatever i guess ill just install it and hope for the best. My midrange power feels kinda weak anyway im guessing the dj needle will help that.
It will help. While dynoing might be the absolute scientific pursuit for performance, we're not dealing with unknowns here. The two different versions of the Dynojet are known quantities with practically guaranteed results. Will it produce big power gains?...much higher speeds?...No. Will it produce improved driveability, better response, a more enjoyable powerband?...yes. If done right, and it's not a hard install, there will be modest power gain but definitely a more enjoyable bike in the way the power is delivered.
Old Nov 15, 2012 | 11:30 AM
wildcard's Avatar
The new needle is going to help alot i think. On your setup you could probably go with the 124 DJ main if a 125 keihin seems a tad lean, as i think that would be equal to a 130 or so keihin jet orfice size wise IIRC.
Old Nov 15, 2012 | 09:16 PM
Warren3000's Avatar
Alright well thanks everyone for the jetting help im looking forward to the results of the dynojet kit.
Old Nov 16, 2012 | 01:38 AM
Landon's Avatar
Jetting sounds very close to mine. I run the stock needle no shim with a 125 main. Runs perfect and the spark plug is just the right color. I would leave it alone. I also have the KDX snorkel and an FMF slip on.
Old Nov 18, 2012 | 12:59 AM
Warren3000's Avatar
Hmm my spark plug is a little on the white side so...
Oh yea and also what about drilling the carb slide hole 7/64" while i install the dj kit?
Old Nov 18, 2012 | 03:44 AM
Do just as the instructions say. One DJ kit instructs you to drill the slide while another sends a new spring. Either way, follow the instructions and it helps improve throttle response.
Old Nov 24, 2012 | 03:03 AM
Warren3000's Avatar
Installed the dj kit with the 240 main needle at 3rd clip and 3 turns out on the a/f screw.. overall the power is smoother with slightly better throttle response throughout the entire rpm range. Also there is less popping on decel. Im satisfied
Subasaki
Mar 7, 2015 12:32 PM
destro
Jul 30, 2010 02:08 PM
kx slaughter king
Jul 27, 2008 01:39 PM
marc11
Jun 3, 2008 11:58 AM
firstninjabike
Joke section!
Feb 3, 2007 07:25 AM
