to much traction new kendas
Old Nov 7, 2009 | 08:49 PM
bschoolz1's Avatar
Default to much traction new kendas
went to uhwarrie nat.park here in n.c 2nd time out with the new *****. after a two hour ride we were in the parking lot having lunch and my rear tire went flat. the air valve was bent. i guess i need a rim lock. i cant believe they dont come stock on the rims.im sure it's no big deal any help would be appreciated
Old Nov 7, 2009 | 09:09 PM
Not sure what you're question is. What size rim lock to get? Look on the rim, the rim size should be stamped, probably 2.15" I can't recall off the top of my head. That's the size rim lock you need. I think the front is 1.85", maybe?
I've ridden at Uwharrie several times, and it is rock city, very rough in some places.
http://www.vimeo.com/2550824
http://www.vimeo.com/1222276
Old Nov 7, 2009 | 10:13 PM
bschoolz1's Avatar
Default rim lock
i wasn't sure if there was a size or make i should get. oh yea rock city i did get a good ride in before the flat
Old Nov 8, 2009 | 02:07 AM
Yep, 2.15 size. bs, what pressure were you running when you spun the tire on the rim?
Old Nov 8, 2009 | 03:06 AM
RimBender's Avatar
rocky mt motosports, tusk brand 2.15, good as any of them
was the tire stem installed straight up to start with? not just wrenched up straight the stem nut (which should be left loose fwiw)
What was used for mounting lube?
You may had a leak, then it moved when it went flat.
Old Nov 8, 2009 | 10:31 AM
WestOzKLX's Avatar
Talon 2.15.
Old Nov 8, 2009 | 07:36 PM
MaverickAus's Avatar
even when you put the rim lock in leave the valve nut loose otherwise you will rip more stems. If you ride over 50 mph you will need to balance the rim.
Old Nov 8, 2009 | 07:41 PM
LearjetMinako's Avatar
Never had a problem with tubes ripping. Thou I always keep the tire pressure at 22psi.
Old Nov 9, 2009 | 11:51 PM
bschoolz1's Avatar
Default air
18# put the rim lock on yesterday
Old Nov 10, 2009 | 12:07 AM
skubidoobie's Avatar
tore 6" out of my stock rear tube, rimlock is a must
