MPG? What's yers?
Old Aug 9, 2011 | 04:46 PM
Lutz's Avatar
Originally Posted by Borischan
His conversion is correct..... for the UK gallon, which is bigger than US
I get 59mpg (US), 70mpg (UK), 25kpl
Doh! I hadn't even considered the Imperial Gallon. Silly American!
Originally Posted by rgoers
My speedo ('09 KLX250s) was off -9.7% from the factory. I fixed it with a SpeedoDRD unit. Now I have MPH calibrated to my GPS... exactly to the tenth!
Oddly enough, my ODO is now off by quite a bit... not nearly 10% like the speed was, but somewhere around 3-4%. I have yet to quantify the ODO error exactly, but I will, as soon as my broken collar bone heals.
As stated above, I think from the factory the odo is off by about 6% high, whereas the speedo is off by about 10% high. So if you adjusted down by 10%, that explains why your odo is off 3-4% low (?) now. Unfortunately anyone who makes the correction needs to choose which to get right. I'd personally go for a correct odo, since I use it for tracking fuel consumption/range, tracking route distances, etc.
Old Aug 9, 2011 | 09:11 PM
rgoers's Avatar
Originally Posted by Lutz
Doh! As stated above, I think from the factory the odo is off by about 6% high, whereas the speedo is off by about 10% high. So if you adjusted down by 10%, that explains why your odo is off 3-4% low (?) now. Unfortunately anyone who makes the correction needs to choose which to get right. I'd personally go for a correct odo, since I use it for tracking fuel consumption/range, tracking route distances, etc.
I was considering splitting the difference between the two.
The way it is now; my speed is dead-on and my ODO reads LOWER than actual miles. I should leave it that way for at least another 800 miles to offset it reading HIGH for the first 800 miles.
Old Aug 10, 2011 | 03:45 AM
sindico440's Avatar
How could you get it corrected (Odo or Speedo)??
I really didn't understand how could you do that.
Old Aug 10, 2011 | 05:57 PM
gonzo's Avatar
63mpg regardless to tire type on a stock motor/exhaust.
Old Aug 10, 2011 | 07:23 PM
45 to 50 mpg, actual, with mileage measured by a Vapor computer and compared/corrected with GPS.
With the Vapor, I also get actual Ride Time. My average velocity is somewhere around 7 to 10 mph, and average fuel burn rate is around 2 to 3 or more hours per gallon, which I think speaks either to my very slow riding techniques and/or the tight, twisty 1st & 2nd gear trails we often find ourselves on
JaBr1884
Ninja 250R
20
Oct 24, 2007 03:01 PM
meangreenman
Ninja ZX-14
13
Sep 4, 2007 09:33 PM
woodsman88
Jun 17, 2007 10:48 PM
freedom_fri911
Ninja 500R
17
Feb 4, 2007 10:52 PM
jds636
Oct 17, 2005 11:46 PM
