Moose Racing Jet kit
Old 05-01-2014, 12:28 PM
ianmcdca's Avatar
Default Moose Racing Jet kit
Has anyone used this jet kit for their bike? Just wondering if there`s a reason most are using the Deejay kit.
Thanks.
Old 05-01-2014, 04:15 PM
wildcard's Avatar
im pretty sure the moose is just a rebranded dyno jet.
Old 05-01-2014, 04:31 PM
From the Moose site:
"Moose Racing Dynojet jet kits provide a simple and affordable solution to carburetor tuning problems"
Yes, pretty sure same as Dynojet as wildcard says.
Old 05-01-2014, 08:50 PM
AndrewGMoto's Avatar
FWIW,
I have a moose racing jet system installed in mine, which I bought used (kit pre-installed). Also came with the fmf powerbomb header. I removed the stock snorkel, as well.
Old 05-02-2014, 04:04 AM
ahnh666's Avatar
used moose racing kit...it is the dyno jet kit with added parts like drill bit, screw to remove plastic plug, etc...
part no: 1007-0366...moose kaw 09-10 klx250sf...vn-p# mq2182.001....includes main jet dj112, 116, 120, 124, 128, 132...fuel needle dno228, e-clip de0001, two adjusting washers dw" 0001, slide spring dsp0027, plug drill dd 5/32 & screw ds0001
Old 05-02-2014, 12:12 PM
wildcard's Avatar
the DJ kit comes with the bit and screw to remove the pilot screw plug too. I would bet money that they are identical besides outside packaging.
Old 05-02-2014, 01:37 PM
ianmcdca's Avatar
Perfect! Thanks. Will post back when installed.
vtgreen
06-17-2010 09:42 PM
scottma978
04-15-2010 03:00 AM
Dready
09-29-2009 01:54 AM
maineack bob
04-22-2009 09:11 PM
LaurenOE
03-20-2008 02:32 AM
Quick Reply: Moose Racing Jet kit
