Moose Racing Jet kit
Has anyone used this jet kit for their bike? Just wondering if there`s a reason most are using the Deejay kit.
Thanks. |
im pretty sure the moose is just a rebranded dyno jet.
From the Moose site:
"Moose Racing Dynojet jet kits provide a simple and affordable solution to carburetor tuning problems" Yes, pretty sure same as Dynojet as wildcard says. |
FWIW,
I have a moose racing jet system installed in mine, which I bought used (kit pre-installed). Also came with the fmf powerbomb header. I removed the stock snorkel, as well. |
used moose racing kit...it is the dyno jet kit with added parts like drill bit, screw to remove plastic plug, etc...
part no: 1007-0366...moose kaw 09-10 klx250sf...vn-p# mq2182.001....includes main jet dj112, 116, 120, 124, 128, 132...fuel needle dno228, e-clip de0001, two adjusting washers dw" 0001, slide spring dsp0027, plug drill dd 5/32 & screw ds0001 |
Originally Posted by ahnh666
(Post 510123)
Perfect! Thanks. Will post back when installed.
