Mixture screw - Richer/Leaner
Old Mar 6, 2012 | 01:41 AM
Brieninsac's Avatar
Default Mixture screw - Richer/Leaner
I'm getting conflicting info. Which way is richer?
Old Mar 6, 2012 | 01:44 AM
redpillar's Avatar
out is richer
Old Mar 6, 2012 | 03:04 AM
Yeah, a few of the sources of info on the style of CV Keihin on our KLX sound confusing when talking about the mixture screw operation. One of them we use the most doesn't clarify when it changes from describing air flow versus fuel flow. Here's a link that better describes that the 4 or so tiny holes in the venturi at the bottom of the throttle butterfly as being actual fuel holes. Air passing in the venturi is pulling fuel out of those 4 holes which lead down into the pilot jet. Some or all of them are controlled by the fuel mixture screw. This clearly means it's metering an amount of fuel that's flowing from the pilot jet circuit and into the venturi.
Keihin CV Carb
Old Mar 6, 2012 | 04:00 AM
redpillar's Avatar
as usual, more succinctly put
CC_Rider
Nov 14, 2013 12:44 AM
sdmartineau
May 16, 2007 09:32 PM
Bad Bear
Aug 28, 2006 11:28 PM
krntl13
Jul 23, 2006 02:58 AM
ZX_9r
May 13, 2006 06:46 PM
