megabomb header melting airbox issue
Old Aug 26, 2012 | 06:45 AM
2veedubs's Avatar
I agree. Loosen all the bolts on the system, wiggle it around to get the best fitment/clearance and start to tighten at the front and work your way back. I have no melting, but did find I needed to add a washer at the front muffler mount as it did not sit flush when test fit. If I had not done that it may have pulled in too close to the airbox? FMF does seem to have alot of fitment issues on various bikes.
Old Aug 26, 2012 | 02:31 PM
RimBender's Avatar
nothing aftermarket ever fits without futzin around, LOL. I'd guess FMF made their jigs to a 300 which may have slight differences in airbox and subframe.
Old Aug 26, 2012 | 04:32 PM
WHIP-N-DIP's Avatar
Pogiboy: Already tried washers on my last bike, but didn't have enough.. should do the trick.. i'm not feeling the lowering bracket so much
Old Aug 26, 2012 | 05:39 PM
JoelThailand's Avatar
I think the airbox on the efi bike is slightly bigger or lower than the US carb model from what i've seen in pictures on here.
I wasn't feeling the lowering brackets when my mechanic suggested them, I figured it would be a temp measure but that was 10 months ago & there still rock solid & looking pretty permanent now.
Old Aug 26, 2012 | 05:45 PM
RaceGass's Avatar
Not much else you can do to get the needed clearance. Lowering brackets seems like a decent solution. The Powerbomb header doesnt have the same issues when running a two bros canister.
Old Aug 26, 2012 | 07:31 PM
ahnh666's Avatar
did a really long ride on freeways at 80+ mph...and some twisty mountains...heatshield prevented pants from melting...airbox okay...but, temp were 60s today...not a great test ride
Old Aug 27, 2012 | 06:50 AM
toyotabuilder's Avatar
header wrap.
Old Aug 27, 2012 | 08:33 AM
250SM's Avatar
What sort of heat shield are you using?
Old Aug 27, 2012 | 09:53 AM
grahamgower's Avatar
hmm...installed the megabomb today and i don't see the header pipe even coming close...the slip-on pipe connects and that pipe only one the appears close to the airbox...unless the heat from the megabomb is increasing the overall temp of the exhaust pipe and muffler....hmmm....i'll keep a close eye on mine...i may just wrap the the entire header and muffler pipe....can't believe my pants started melting so quickly...not sure if the heatshield is going to be enough...
The FMF heatshield works fine. I ride a lot in shorts, and no problem.
Old Aug 27, 2012 | 03:41 PM
ahnh666's Avatar
updating both megabomb threads..haha...but, yes...the fmf heatshield is working fine for now...i don't think i have any hot weather coming up to test it in hot weather...sf tends to be cooler...
Klxster
Apr 2, 2014 01:40 AM
zippets
Oct 30, 2013 04:40 PM
WHIP-N-DIP
Jun 29, 2012 06:28 AM
devinnived
Sep 18, 2010 01:32 AM
