max rear sprocket size with a 13t/108chain
just got access to some new offroading trails with lots of hills and technical terrain. my 13t/45t (108 link chain) just isn't cutting it... and darned if the 108 chain isn't near new :-( how many teeth can i go up on the rear with the 108 chain?
I'm pretty sure I had 110 links with a 49 rear (13/15 front).
Just found a thread where a couple members had 46 with 108.
Not really recommended for chain and slider longevity, but maybe try a 12 on the front to see what that does for you. If its too much, you'll know a 46 or 47 may be what you're looking for.
We could use a table in the FAQ thread with gear combinations and chain lengths.
Just how much extra wear and tear does a 12t do to the chain and slider? Thanks for the input.
I've never come across a 12 tooth for the KLX250.
+ on the 13/47. Really low gearing. If you actually buy a chain don't do the 108, do a 110 or maybe 112. There should be enough room to fit the 13/47, but it will allow a 15 if you wanted to gear up.
Second post from this thread might be helpful
14/45 gearing for KLX, do I need a new chain too? - Touring Forums | GT-Rider
The page they link to is dead, so no idea if those combos are accurate.
