maintenence question
There's so many different opinions on this. Mine is long as you are being reasonable in the type of oil you are using & the frequency you are changing it (ie you are not changing with cooking oil every 50,000 miles) it's going to be pretty hard to hurt an engine with 'incorrect' oil change philosophy. Follow the manufacturers recommendations and if you sleep better at night by exceeding them, do it!
2009 klx250sf....
i just check the oil daily...i'm usually running at around 8,000 rpm daily on the highways for commuting...after about 3,000 miles, the oil level starts getting closer to the bottom line....i just stick to 3,000 mile oil changes (about 3 months of riding for me)....currently using semi-synthetic yamalube 10w40...if you changed your oil at 2,000, why would you think you need an oil change soon after 400 miles?
8,600 miles - valves were out of spec and required new shims (valve adjustment)
8,000 miles - i should have replaced my rear tire, but now i have 9,300 miles and my rear tire is past the wear indicator....made an appointment tomorrow....
looking at the chain and sprockets, i think the 15t and 39t rear will last 20,000+ miles....
thanx for the input everyone ive gotten enough answers to figure out that im just gonna come up with my own schedule for changing the oil because my head is ready to spin from all these answers
Well I know I don't need to change it every other ride, but 7,500 miles seems to be a lot in between changes. I don't think I'll ever go that long
This ^^^^
1stCruiser
Apr 23, 2011 03:27 AM
