maintenence question
Old Jun 11, 2012 | 12:45 AM
teamgreenrider91's Avatar
Default maintenence question
my klx is an 07 and the oil was changed right before i bought it with exactly 2000 miles on it. well ive put about 400 on it since then and im sure im about due for an oil change but i was just wondering how often most of you go before changing the oil and what weight/brand do you guys run and why?
Old Jun 11, 2012 | 02:05 AM
Brieninsac's Avatar
I believe your next interval would be 3,750 followed by 7,500. I use a SAE 10W-40. I think any major brand is fine.
Old Jun 11, 2012 | 02:10 AM
stephenmarklay's Avatar
I am crazy and do like 500 -750 miles for oil and filter every other. I just did oil and filter this morning.
I am not saying to do this I am just saying that is what I do.
I use Rotella 15W-40. It is a heavy duty oil that a lot folks use in bike of all kinds. It a bit expensive at about $13.xx/gallon
Old Jun 11, 2012 | 02:24 AM
wildcard's Avatar
i change mine about every 1500-2000. I ride the poor KLX pretty hard though.
On my ninja i go about 3-4K between changes. 15w-40 Rotella always.
Old Jun 11, 2012 | 02:33 AM
Malves's Avatar
You're gonna get so many answers, your head's gonna spin. I do oil and filter change every 4,000Km and use Motul 3000 20w50.
Old Jun 11, 2012 | 09:21 AM
MaverickAus's Avatar
1,000 km or 6 months
Old Jun 11, 2012 | 09:54 AM
Klxrelic's Avatar
Oil change every 3000 kms. Just regular old 10w30 Dino oil. Filter every 12,000 kms. Also note that I'll soon have 40,000 kms on mine.
Old Jun 11, 2012 | 04:32 PM
whyzee's Avatar
Oil change every 500-700 miles for me. I will only use oil with a JASO MA, MA1, or MA2 rating.
Old Jun 11, 2012 | 05:11 PM
rgoers's Avatar
First few changes were at 80, 800, and 2000. From here on, I will be changing every 2000-3000, or annually, whichever comes first.
Old Jun 11, 2012 | 07:43 PM
ahnh666's Avatar
2009 klx250sf....
i just check the oil daily...i'm usually running at around 8,000 rpm daily on the highways for commuting...after about 3,000 miles, the oil level starts getting closer to the bottom line....i just stick to 3,000 mile oil changes (about 3 months of riding for me)....currently using semi-synthetic yamalube 10w40...if you changed your oil at 2,000, why would you think you need an oil change soon after 400 miles?
8,600 miles - valves were out of spec and required new shims (valve adjustment)
8,000 miles - i should have replaced my rear tire, but now i have 9,300 miles and my rear tire is past the wear indicator....made an appointment tomorrow....
looking at the chain and sprockets, i think the 15t and 39t rear will last 20,000+ miles....
