Lowering links question
Old May 21, 2013 | 12:53 AM
  #41
rebl617's Avatar
I just installed 1" lowering links from Burkhart on my 09. Seat height wasn't my issue, I have a 50 series tire on the rear which is an 1" taller than stock and was causing a high speed front end wobble at about 70 mph indicated. With the lowering link I still have a wobble but it doesn't start until about 80 indicated, next it's time to balance the front and rear tires see if that gets ride of the wobble.
Old May 21, 2013 | 10:34 AM
  #42
zippets's Avatar
This is what im using and i can lower and raise the bike for any kind of riding i want to do
Soupys Performance, Motorcycle Lowering Kits, Motorcycle Raising Links
Old May 21, 2013 | 03:16 PM
  #43
kntr's Avatar
If you lower the bike in just the rear, how does this affect handling?
I can lower the front fork but only 1/4" or so until it hits the bar. Should I just lower the rear 1.5"?
Old May 21, 2013 | 03:30 PM
  #44
zippets's Avatar
to lower the front you need to get handle bar riser i know a guy that pushed his fork tubes up 1.5"
yes you should keep them the same but if you lower the back more then the front you lose your steering it will act more like a chopper
correct me if im wrong please
Old May 21, 2013 | 03:35 PM
  #45
kntr's Avatar
Ok. That's what I was thinking.
What is the max you can lower the rear without causing problems? I see they make kits for 1" to 4".
Is there anything else that needs to be adjusted when you lower the bike? What about the kickstand?
edit: I read in a few threads that after you lower the rear you have to increase preload on the shock or even replace the spring. Wouldn't that just raise the seat height right back up?
Maybe I should just take the seat in and have them shave a few inches off the foam.
Old May 21, 2013 | 05:17 PM
  #46
zippets's Avatar
no it would not raise the seat height back up when you lower the bike it also changes the leverage that the frame attaches to the shock this is why you need to change the spring tension ( like if you where seating all the way towards the back of the bike)
soupys also sells adjustable kick stands but depending on how far you want to lower the bike look at seat concepts they are probley one of the most comfy seats around and lowers your seating position 1-1.5" and you can ride hundreds of miles without monkey butt
i'm using both because of the ajustbilty of the links this wat you don't have to lower the front much
Old May 22, 2013 | 12:44 AM
  #47
rebl617's Avatar
I've been racing harescrambles since 1995 on various brands, the latest was a 450 GasGas. I think the klx250 turns just as good if not better in the woods. Forks are even with the top clamp, 1" lower in the rear and the bike rides fine.
Old Aug 19, 2013 | 06:31 PM
  #48
fenderworks2's Avatar
I just did the opposite:
purchased stock lengths from burkhart cycle, and put the bike back to stock.
Wow! this thing is setting high.....i like it
had the KLX4 links from KoubaLink. so it was 2" lower than stock, i thought i liked them but went back to stock.
now i have to figure out how to add some inches to the kick stand
kdick91
Jun 25, 2014 09:00 PM
afboundguy
May 14, 2007 01:25 AM
motodad
KX65
Apr 16, 2007 09:56 PM
kotacam
Oct 2, 2005 08:56 PM
cyclops
May 23, 2005 07:54 AM
