Lowering links for a 2019??
Old May 3, 2021 | 05:22 PM
timtune's Avatar
Default Lowering links for a 2019??
just got a 2019 KLX250 and need to drop it some to fit. Called 3 main shops in Ontario - Royal Dist, Fortnine, GP Bikes and none carried them. Where might I look next?
Thanks
Old May 3, 2021 | 11:58 PM
tooter's Avatar
Get KoubaLinks.
KoubaLink (koubalinks.com)
They work slicker than snot.
They offer various sizes for how much you want to lower your bike. I'm only 5'5", so I lowered my KLX300 front and rear to an unsprung seat height of 30 inches. Now I can flatfoot both feet when stopped.
Old May 4, 2021 | 08:57 PM
Or get some steel flat stock and cut your own. Get the bike on a stand that will allow you to lower it incrementally. Jack it up till the tires just touch, take off the links, then lower it a couple inches (measuring it), then measure distance between centers where the link will bolt on. That is how long a link you need. Flat stock steel can probably be 3/16 thick, aluminum should be more like 1/4", I'd do steel. My brother and a local bike mechanic I knew, both did this. My brother for his KLX250, the mechanic on his KDX200. Not as fancy, but every bit as functional.
Old May 24, 2021 | 09:43 PM
mark smith's Avatar
I have a brand new soupy's 2-4" adjustable link and the matching adjustable kick stand that I will ship to you for $160. if interested call me at 479-970-0056.
bobbyj
Jan 23, 2017 03:13 PM
407guy
May 12, 2011 06:36 PM
customkawi01
Feb 5, 2009 12:54 AM
motodad
KX65
Apr 16, 2007 09:56 PM
cyclops
May 23, 2005 07:54 AM
