Long winded over heating question....stumped..WTF????
So, just an update for anyone else that may experience the same.
Changed thermostat, fan sensor switch, added Motul motocool, and everything seems to be back to normal. Fan comes on BEFORE the light, and light didn't even come on the last 2 rides.
Fingers crossed, but it looks like it's solved.
That is an excellent idea!
My KLX has always had a problem with overheating (Only on road use) when slow in traffice and or **** roads, I have replaced, water pump and radiators already. I am running a digital AFR now on the handle bar, as i thought it was running lean, but all seems to be between 12-1 and 14-1 so should not be overheating due to fuel mixture.
Fan comes on and off all the time. Went out with the wife for a run 150kms last weekend, and anytime we were going up any steep hills the Temp red light would come on. I am away to replace the thermostat and temperature warning light. I have also bought a second fan and going to fit that also.
Check your radiator hoses are fitted correctly. The 2 on the right side will fit & look correct in the WRONG configuration. Easily done if not paying attention!
Please correct me if i'm wrong but when Bikeland featured it's 331 motard conversion they got the hoses reversed! The only reason i know this (not because i'm geekishly observant) is a Kawasaki dealer mechanic fitted my red silicon hoses wrongly & my bike ran very hot for a month until this error was spotted, which was really annoying.
Just a thought!
Wrong fitting
Correct fitting
Just a thought!
Wrong fitting
Correct fitting
Thanks mate, will change mine tomorrow. They have been the wrong way since i bought it second hand 10 years ago now, lol
That's indo style mechanics :-D happen all the time to me. Need to triple check everything
Yes, the pump connections are reversed. The fitting that leads to the center of the cover is the suction side-it should come from the rad. outlet. The fitting on the outer scroll of the cover is the pump outlet, it connects to the supply hose on the base of the cylinder. Get those swapped and your problems should be gone.
