lighting problems
Old Mar 15, 2009 | 08:35 AM
fgk228's Avatar
Default lighting problems
as many of you know, with the klx head light, it is very difficult see at night. low beam is great, if you dont need to see more than 5m infront, high beam is great if you dont need to see less than 5m infront. when going around coners is fine is you dont need to see. this is all in the bush, so there are no street lights. the only problem i have with the current lights is i can see the big F***ing hole im about to ride in to.
i have tryed to adjust the beam but i just get the same result, just at diffent lengths.
i have try to find the alternater restrictions but it does not say any where. not even in my work shop manuals and supplement. so i was not sure weather extra lights would kill my battery as i ride.
has anyone solved this problem or any suggestions or has the specs on the alternater, i have a 99' klx250h austrailan spec
Old Mar 15, 2009 | 03:24 PM
al.b's Avatar
Default lighting
hi fgk228
just wondering if you are still using the stock bulb.
Have a look at pia lighting, They make alot of different bulbs.
I am looking into getting one myself, but there are several diffent
styles to choose from. They are fairly expensive though.
al.b
Old Mar 15, 2009 | 09:50 PM
mudjunkie's Avatar
Thumbs up
I replaced the stock bulb with a Silverstar...It does the trick for me. Walmart carries them also for about 25 bucks CDN Its the H4 base BTW....good luck.
Old Mar 16, 2009 | 12:17 AM
WestOzKLX's Avatar
Get a 100/55 watt bulb. Still got the 55 on dip but the 100 watt main makes things so much clearer at night. The stator can handle it. The lens is glass too so no problems with the extra heat.
Old Mar 16, 2009 | 05:26 AM
tremor38's Avatar
I'd do like WestOz is doing (55lo/100hi). Even in High beam ,that would leave you with about 20W headroom with respect to the KLX charging system capacity.
Old Mar 16, 2009 | 06:23 AM
Xplosivo1's Avatar
What are the stock specs for the light? I will agree that it is definitely lacking.
Old Mar 16, 2009 | 07:32 AM
fgk228's Avatar
Originally Posted by al.b
hi fgk228
al.b
not sure if it is stock. i bought the bike in january and the last owner didnt say anything, but it is pretty **** so im geuss it is stock.
it was funny in the bush the first time i got couaght at night, lucky my friend was in his 4wd and had his light rack on full. but every time i pulled away it was very dark.
im in aus so some web site would be great if you could link me up.
Old Mar 16, 2009 | 12:12 PM
WestOzKLX's Avatar
Kmart, Supercheap Auto, Big W. Take your pick you'll find a 55/100 in a H4 . Try it out. Cheap solution for around $18.
Old Mar 16, 2009 | 02:04 PM
al.b's Avatar
Default piaa lights
G'day mate al.b again
the web site is www.piaa.com .
sorry i missed an a on the name.there is a dealer locater on
the site. i would have looked for you but your in the land of oz.
here in canada they go for 45$ to 65$ cdn. not cheap but they
do work great,i have seen a few on some bmw's and they are bright.
there's the hid lighting also verry expensive about 700$ cdn.
like daylight at night.never seen them on a bike around here.
only on the movie dust to glory. great movie though.
look up www.bajadesigns.com they have all the info on the hid.
just some other ideas to spend your money on.let us know
what you got and how it works,good luck.
al.b
Old Mar 17, 2009 | 07:20 AM
MaverickAus's Avatar
You guys are funny, the KLX headlight is great, go ride a bike with a 6v system and you will thank the lord for the headlight on the KLX.
