License plate bolt lights
I wonder if you put a couple washers behind the lights (so they stick out farther) if it would'ntspread the light out more on the plate.I like this idea and might give it a try.
ORIGINAL: millman
Yeah it appears that your plates are stamped. In NY the plates are nothing more than decals on tin, they would probably work much better on this style plate, or like others have said, maybe you can shim them slightly.
ORIGINAL: mooredan
As we used to say in the Navy: "What do you think you got? ...a calibrated eye?"
Mooredan,
I did a similar mod with an led fixture, I like yours, "just bolt it up" and you got the lights! ....How many led's per bolt? i think my "lightbar had 4 or 5 led's
looks light you have enought light..Great find!
I used the same ones, only got them from Summit Racing.
https://www.kawasakiforums.com/m_110531/tm.htm (post #6)
