Left hand switch assembly replacement
Old Oct 11, 2007 | 04:05 AM
mooredan's Avatar
Default Left hand switch assembly replacement
http://klx250s.suncup.net/LeftConsole/index.html
Old Oct 11, 2007 | 08:37 PM
mudjunkie's Avatar
Default RE: Left hand switch assembly replacement
Dan..is the push button a momentary switch or does the button stay in when you push it?...reason being...I'm looking for right hand control replacement to get rid of the swivel type start button and go with a momentary push button...straight in --- straight out.
Old Oct 11, 2007 | 10:58 PM
jaylaudeman's Avatar
What type of handgaurds are those?
Old Oct 11, 2007 | 11:27 PM
Ohhh, that evs shortylever looks nice.
Old Oct 12, 2007 | 12:22 AM
mooredan's Avatar
It is a normally-open momentarypush button. It does not "stick" when pushed in. (That would be really annoying being hooked up to the horn).
So it is spring loaded so that when it is released, it goes to theopen position.
Ashooked up to the horn circuit, it momentarily provides a ground to the horn.
Old Oct 12, 2007 | 12:27 AM
mooredan's Avatar
MSR Hawkins Handgaurds
Got them from Monkey Butt: http://www.monkeybuttparts.com/pk4/s...7&start=10
Black 7/8" Standard #34-0735 $89.99
Old Oct 12, 2007 | 11:51 AM
vfrpilot's Avatar
I had similar issues when I installed my ASV levers. But I moved the mirror mount inward, brought the clutch bracket outward and removed the chrome jamnut on the lever adjuster and replaced it with a thin jam nut. I've never had any problems. And really like the levers!
WHIP-N-DIP
Jun 18, 2012 02:48 PM
Guido
Sep 8, 2009 10:25 PM
MicroSprint#5
Mar 19, 2008 05:38 PM
1lowGMC
Ninja 250R
Jul 22, 2007 04:06 AM
MK1gti20v
Aug 12, 2005 04:49 PM
