Leaking fork
Old Jul 28, 2009 | 07:54 PM
SnowmanSimon's Avatar
Default Leaking fork
One of my fork legs is leaking oil. Im just wondering if this is a commong thing on the 06 klx250? Someone mentioned to me there could be a piece of dirt stuck under the seal and to use a feeler gauge to try and dislodge it. If this doesnt work can the seal be changed easily? Anywhere I can read up on it? What kind of oil and how much, etc?
Old Jul 28, 2009 | 08:05 PM
roadglider's Avatar
Don't use a feeler gauge use a thin card, try this first it might work. It's not too difficult to change a fork seal however you'll need to either make or buy a fork seal driver. http://www.wonderhowto.com/how-to/vi...als-199503/eck out
Old Jul 28, 2009 | 08:09 PM
roadglider's Avatar
That vid shows a Showa twin chamber fork the KLX fork is easier. There is a service manual for free on this forum somewhere download it and read it through. If you decide it's more than you want to tackle. Remove the forks from the bike yourself and just take the forks to the shop it will save you a few bucks.
Old Jul 29, 2009 | 10:40 PM
cmon6969's Avatar
I just had mine done at Factory Connection. I bouught my bike there and thay did it in about 4 hours. I had hever springs put in to it and thay did a compleat rebuild total cost 390. the bike rides a lot better
Old Jul 30, 2009 | 12:14 AM
neilaction's Avatar
I used a thin piece of plastic film.
Worked well.
An old negative would be good.
Old Sep 15, 2009 | 02:49 PM
What kind of oil should I put in? Any idea how much?
Old Sep 15, 2009 | 03:01 PM
WestOzKLX's Avatar
Hi Neil. Howd ya get on down south. Any piccies?
Old Sep 15, 2009 | 04:46 PM
JasonFMX's Avatar
Mine has been leaking since I got it. I tried using something to slip up there to clean it out and it didn't work. I just refilled it with fork oil.
Old Sep 15, 2009 | 05:32 PM
How much should I put in?
Old Sep 15, 2009 | 10:12 PM
JasonFMX's Avatar
haha, I have no idea. You'd have to get a shop manual to see how much is in there to begin with....then estimate how much ran out and refill it.
I just got a syringe out of one of the wife's hair dye boxes and started squirt oil down in there. I must have fired down at least 180 CC's this time, and several months ago I probably put down 50-60 CC's .... at least, from memory thats what I believe it to be.
