Latest mod: front sprocket +1 teeth
Old Apr 9, 2011 | 08:51 PM
ndery's Avatar
Default Latest mod: front sprocket +1 teeth
Yeah ! I just went +1 teeth on the front sprocket (from 14 to 15)...so I am an happy rider now !
The reason I wanted one more teeth on the front sprocket is because I do a bit more pavement than dirt but I'll never change the KLX witch I like very much. So going one more teeth dropped the rpm about 500rpm at 60MPH without compromising too much power. I have to say I'm a light rider (150 pounds) so the tiny 250cc power plant doesn't suffer too much !
I dropped the rpm's, so for the vibrations in the rear end ! What a piece of cake the daily commute to work will be !
Old Apr 10, 2011 | 12:26 AM
ns503's Avatar
I am in the process of getting a 13, might go one up on the back also depending how the 13 works out. I couldn't imagine trying to ride any kind of tight trails or woods with a 15.
Old Apr 10, 2011 | 12:40 AM
LearjetMinako's Avatar
I've messed up. I never changed my gearing, but I found out recently that on Kenda's website, a 4.50x18 is taller than a 4.60x18. So in effect, it makes if feel like a lower final drive ratio or like adding those extra teeth on the sprockets.
Old Apr 10, 2011 | 02:29 AM
KLXHunter's Avatar
anyone know where i can get a 13T for a 2010?
Old Apr 10, 2011 | 02:39 AM
punkenduro09's Avatar
try a 130 606, or probably any 130/140 you can fit on the bike. makes it feel/handle like a tw200, and equivalent to a tooth on the front sprocket.
Old Apr 10, 2011 | 02:49 AM
Biff-a-nator's Avatar
Just ordered one a little while ago from Rocky Mountain.
Primary Drive Front Sprocket 13 Tooth - 2009 Kawasaki KLX250S 1021470075 $8.99 1 $8.99
Primary Drive Front Sprocket 13 Tooth | Rocky Mountain ATV/MC
Old Apr 10, 2011 | 12:04 PM
KLXHunter's Avatar
Biff - the 2009 will fit the 2010?
Old Apr 10, 2011 | 05:10 PM
Yes. They are the same bike.
Marty
Oct 12, 2007 10:03 PM
toad1025
Ninja 650R
Jul 27, 2007 03:06 PM
toad1025
Ninja 650R
Jul 16, 2007 05:29 PM
jellyfish
Feb 24, 2007 11:07 PM
Gravy Train
Oct 18, 2006 04:14 PM
