KX450 forks springs ?
Old Mar 16, 2013 | 02:12 AM
DustyCowboy's Avatar
Default KX450 forks springs ?
My friend is offering my his KX450 forks springs. Do you know if they would fit in my 09 KLX250S forks? I think his KX is 1 or 2 years old.
Thank you!
Old Mar 16, 2013 | 02:57 AM
Brewster's Avatar
Not likely, but you can check the spring dimensions here:
Race Tech Suspension
Ride on
Brewster
Old Mar 16, 2013 | 03:55 AM
No kidding...the spring diameter on a KX450 has got to be outside those of the KLX250. I don't even know what the KX fork diameter is, but I'll be it's way bigger than the 43mm setup on our KLX at 43mm. Length and spring diameter are probably not even close to suitable between the two forks. Plus, isn't the newer KX450 just a single spring setup? What year KX forks are we talking about?
Old Mar 18, 2013 | 12:23 AM
Ok thank you guys!
racerx596
Jun 12, 2013 02:19 PM
crashnburn366
May 28, 2012 03:30 PM
Annie Oakley
Mar 29, 2012 12:39 PM
Stoner
May 3, 2008 02:25 PM
foggys916
Oct 5, 2007 05:24 PM
