Kouba extended fuel mixture screw?
Old Apr 30, 2013 | 06:28 PM
cmott426's Avatar
Originally Posted by 250sf09
Got my kouba screw in and installed, just wondering, what seems to be the normal turns out for this screw on the 250? I keep moving between 1 and 1.5 and can't seem to figure out what is best, getting a lot of popping on decel the more out I am so too rich?
Too lean or an airleak in the exhaust.
Old Apr 30, 2013 | 07:14 PM
250sf09's Avatar
So I was screwing with it for an while, did the stall test with 1k rpms to see when the bike would stall, stalled at 1 turn out for lean and 4.5 turns out for rich. Set the screw to about 2.75 turns out and a lot less popping on decel, maybe only pops once or twice on decel from high rpms down to 4k, seems to be running a lot better, hope my gas mileage isn't way off compared to before. Does anyone notice any mileage difference switching from stock mixture screw to the kouba FS-2?
Old May 1, 2013 | 04:14 PM
donaldor's Avatar
Start at 2 turns out from gently seated position. Start bike and bring to operating temp. Slowly turn the screw in until you hear the idle begin to drop and back out 1/8th turn. Now turn the screw out until you hear the idle begin to drop and turn in 1/8th.
Somewhere between those 2 screw positions is the perfect mixture adjustment for your bike at your altitude. I prefer to turn the screw in (lean the mixture) until the idle drops and back out 1/8-1/4 turns.
Once you get a feel for this you can easily tune your carb based upon your environment [altitude].
Old May 1, 2013 | 07:38 PM
ahnh666's Avatar
anyone have a picture of the screw on the carb/on the bike?...i want to see how much easier it would be vs. just using the little phillip head (which i think is pretty easy)
Old May 1, 2013 | 08:16 PM
Brieninsac's Avatar
IMO, for as often as you need to adjust your mixture screw it's a waste of money.
Old May 1, 2013 | 09:12 PM
durielk's Avatar
If you always ride at the same elev or you have a CV carb, adjustment should be rare.
If you have a slide carb and ride at different elevations, get the kouba.
Old May 2, 2013 | 12:14 AM
RaceGass's Avatar
Small price for the convenience it provides, easily adjusted while your riding... Even when the engines hot
Old May 2, 2013 | 10:03 AM
250sf09's Avatar
The paper that comes with the screw says to adjust the idle down to right before it stalls which was about 1k rpms for me, it stalled at 1 turn out for lean and 4.5 turns out for rich so I figured 2.75 turns out was right in the middle. But the paper also says not to have the screw turned out more than 2.5 turns because it may vibrate out. I have been running it with the screw about 2.25-2.5 turns out and seems to be running great, hardly any popping, decent gas mileage, and seems like it has a little more get up now.
Old May 3, 2013 | 07:38 AM
linkin5's Avatar
Mines been 2 3/4 turns out for 3 years now and has never moved in or out.
Old May 4, 2013 | 05:59 PM
Corey-saki's Avatar
I bough one at my local Harley shop, not a Kouba but they had several in stock and evidently some Harleys use the same carbs or similar to the Klx's
