klx300 2021
Old Dec 8, 2020 | 08:31 PM
doum's Avatar
Default klx300 2021
klx 300, efi, street legal, directly from kawasaki for 2021 in canada and usa!
Old Dec 8, 2020 | 08:36 PM
doum's Avatar
Old Dec 9, 2020 | 12:32 AM
GBAUTO's Avatar
Kinda what Kawi should have done from the get-go.
Old Dec 9, 2020 | 02:09 PM
I thought everyone knew this news by now...LOL! Yes, it's the logical step for Kawasaki for the KLX. When I put our shop's first "updated" KLX300R together at the end of 2019, I kind of felt that the platform would transfer over to the S-Model. Resurrecting the off road model with e-start and FI sort of tipped that off. The only disappointment I have for the new 300-S is that they didn't transfer the 11.2" of travel over from the R-model. Short-leg'ers may complain about higher saddle heights, but the longer travel like the '06/'07 S-models had made then more off road worthy IMO. Midgets can ride the KLX230.
Old Dec 9, 2020 | 04:29 PM
Klxster's Avatar
The new 300 Hondas (CRF300L and Rally) will be interesting too. Getting 283cc via stroking the 250 .. If the info is correct, it's a 27hp engine, stock.
Old Dec 9, 2020 | 05:34 PM
durielk's Avatar
Let's see putting the 283 crank in a big bore will get you 396cc's. .... and a lift in 3rd gear if your clutch is strong.
Old Dec 9, 2020 | 07:26 PM
Klxster's Avatar
Yep, already thot bout that - B&B Cycle Restorations (Bill Blue) BB kits for the CRF250L.. If his BB pistons will work with the longer stroke 283 crank, then WOW ! Can you say 30+ hp Rally300 !
Old Apr 29, 2021 | 09:44 AM
Krn_taco90's Avatar
Default Kawasaki klx 2021 Sm tire swAp
Anybody know what tire would fit a new 2021 KLX 300 supermoto to put new wheels and tires to transform it into a klx 300R?? Any aftermarket ideas and leads is much appreciated!!
Old Apr 29, 2021 | 09:55 AM
Krn_taco90's Avatar
What bikes are universal to klx 300 Sm ? To convert to dirt ?? I want 21/19 setup what do I need to do help!! Thanks Lot
Old Apr 29, 2021 | 02:37 PM
Sid Post's Avatar
Your first issue is suspension. The KLX-300R has more ground clearance and suspension travel.
The rear is probably easily fixed with a shock swap, possibly with the help of some linkage. For the front, you are looking at new forks to get the travel right.
With that being said, the frame was tweaked to provide more lively handling on the street so, handling may never be right without a new, possibly custom, triple clamp.
I have demoed the KLX-300S and KLX-300SM and can confirm they do handle differently on the street. The KLX-300R will follow the KLX-300S.
