Klx250sf supermoto wheels and tires
Old Jul 19, 2019 | 12:54 AM
allinarush's Avatar
Default Klx250sf supermoto wheels and tires
Tires have probably about 75 miles on them. Still have the lil rubber do dad's on them. Wheels are balanced.
asking 600 buyer pays shipping which is usually about 80$
Old Jul 19, 2019 | 05:24 PM
Tacoma660's Avatar
why you selling?
Old Jul 19, 2019 | 06:18 PM
allinarush's Avatar
I have dirt wheels and they taking up space.
Old Aug 3, 2019 | 11:17 PM
Oblio7's Avatar
Will these bolt directly to a KLX250S dual sport? I know the suspension travel is longer on the dualsport, but are the brake rotors/calipers and wheel hubs/axles the same?
Old Aug 4, 2019 | 12:18 AM
allinarush's Avatar
I bought dirt wheels and they bolted directly on. So assume yes.
Old Aug 4, 2019 | 11:21 AM
Have to use the same size rotors on both sets of wheels and be the same generation.
Pre-2009 has a mechanical speedo drive, 2009 up have electronic, won't swap out.
Then there is the brake rotor, unless changed, they will not swap out. Look at the picture, the rotor is significantly larger than the stock S rotor. The SF has a 300mm rotor the S has I believe a 270mm rotor, definitely smaller diameter. The carrier for the caliper is made to suit the rotor size. You can buy a $30 used KLX300 or 250 small 270mm rotor on ebay to have S size on both wheels, or go big buck and buy either an OEM or aftermarket rotor for the SF and have the larger SF size. That will give you a set of wheels that will swap in and out.
Schafer08
Apr 16, 2019 10:20 PM
zl PINHEAD lz
Feb 4, 2019 08:47 PM
dngrrngr
Jun 11, 2010 06:00 PM
m6thompson
Aug 14, 2008 12:32 PM
