Klx250sf getting no spark
I'm new to these forum things, but I just picked up a 2009 klx250sf today and I bought it not running because I was getting a killer deal anyways I brought it home went through it and got it to fire right up rode it around a little and noticed there was a loud rattle in the motor,(cam tensioners) so I looked up and ordered a Krieger manual one, just waiting on that but when I was riding it 3rd gear started popping so I went back home let it sit, checked the plug and it was getting no spark so replaced the plug and still not getting a spark, anyone know why?? Thanks!
First, check the basics-battery terminal clean and tight, verify that the main ground terminal(it's located on the l/h side of the engine case above the front sprocket) is tight, check the 20A fuse(under the seat on the starter relay), check the harness connectors for the ignition module(under the l/h side cover) and the pick up coil. If all of those are good then I would suggest you download the service manual https://www.kawasakiforums.com/forum...manuals-37525/
and go to the electrical section page 16-45 and follow the flow chart to isolate the cause of the problem. You will need a volt meter/multi-tester to check resistance and voltage on the harness.
It's a little time consuming but it's the only way to accurately test the system
jayden
Apr 29, 2006 10:16 PM
