KLX250S OutBack Luggage System
Old 06-16-2010, 11:24 PM
doum's Avatar
Default KLX250S OutBack Luggage System
Just found this, may be of interest for some of you!
Complete luggage system with rear top rack and side mounts for a"unitized" system.
Multiple mount points to distribute the load around the rear subFrame.
No modifications required to the motorcycle to mount the systems.
No drilling on motorcycle required.
Minimizes system weight to maximize load capacity. Most systems under 35# with Pelican 1520 cases
Mild steel tubing construction with black powder coated finish. Easily repaired in the field if required.
System comes with universal side brackets to be mounted on thecases of your choice. (Pelican 1520 recommended - included in this package).
Sturdy Quick disconnect using spring and pin design. Easy on, easy off.
On some the rear turn indicators are relocated for greater
Visibility and safety. Also allows for a range of case mounting positions to suit the rider.
All required hardware is included for installation.
ALL CASES WILL REQUIRE DRILLING TO BE USED ON OUTBACK LUGGAGE SYSTEM.
https://tciproductsusa.com/index.php...roducts_id=716
Old 06-17-2010, 12:19 AM
Miaugi's Avatar
Looks real good....then I followed the link......$650! OMG!
Old 06-17-2010, 03:56 AM
punkenduro09's Avatar
650 and it doesnt include the cases, counts me out.
Old 06-17-2010, 04:06 AM
redpillar's Avatar
Pretty bullet proof cases though. I am not sure what those fancy aluminium boxes cost but I bet they are more than a grand.
too big for my liking but you could pack a lot of **** in there.
Old 06-27-2010, 10:53 PM
sw0ggd0gg's Avatar
WoW if it came with the pelicans then yeah.
YOUR PRODUCTS ARE AWESOME!. I WANNA KEEP MY KLX NOW!
Old 06-28-2010, 04:01 AM
ol'klx-er's Avatar
Default Cases included
Reads to me that the cases ARE included for that 650$
Old 06-28-2010, 03:14 PM
sw0ggd0gg's Avatar
Oh yeah it does
Old 07-25-2010, 02:55 PM
eeore39648's Avatar
Default Dirt Bagz
I have these, Dirt Bagz Ranger. Easy on, easy off. Semi waterproof.
Check out the link, much cheaper than $650
http://www.dbzproducts.com/
Old 07-25-2010, 10:29 PM
Blackheart58's Avatar
I use the Giant Loop Mojave system. Soft, easy to move from bike to bike (that's a GIANT benefit when you have three Dual-Sport bikes), no additional brackets/structure needed. Won't sever your achilles tendon or break your ankle if you drag your foot behind you when you wreck.
Klxster
04-08-2020 02:56 AM
Salinger
01-14-2013 01:54 PM
uk_nick
07-19-2010 03:42 PM
Nobrakes
07-28-2009 11:09 AM
iamsupercool
750
01-07-2006 06:56 AM
Quick Reply: KLX250S OutBack Luggage System
