KLX250S EFI Front fender change
Old May 16, 2017 | 07:25 PM
mrtee's Avatar
Default KLX250S EFI Front fender change
A new OEM front fender is expensive and quite easy to break off road so I am thinking about trying the 2016 KX250 front fender instead. Here is the link:
UFO Kawasaki Motocross MX Front Fender KXF 250 2017 KXF 450 2016 - 2017 Green | eBay
Has anyone tried this mod? will it mount up OK?
Thanks.
Old May 16, 2017 | 09:43 PM
Tacoma660's Avatar
Ill probably be getting one like that if my hack job isnt that good off road. might have to drill new holes only issue i can see or put a spacer in the back so it will clear the neck
Old May 16, 2017 | 09:50 PM
mrtee's Avatar
whats your hack job?
Old May 17, 2017 | 07:11 PM
Tacoma660's Avatar
I trimmed about 6 inches off the front
Old May 17, 2017 | 08:55 PM
jabara572's Avatar
Thanks.
I have a 2014 KX450f front fender on mine, bolts right up. Not sure if they changed the 2016, but a 2014 KX450f is like $20 most places.
I had to use 2 washers on the back to keep it from hitting the frame. The bolts are a little different than our 250, same size and length, but the kx450f has bigger holes in the fender. The kx450 bolts have a "bushing" of sorts built in (whereas our 250 the bushing is molded into the fender itself). Its worth the $6 for the kx450 bolts, it will be much more secure (but i ran with 250 bolts and washers for a while)
Hope that helps.
Old May 17, 2017 | 09:12 PM
mrtee's Avatar
Hope that helps.
Nice one do you have a pic so I can see how it looks with the 09 onwards KLX?
Thanks
Old May 17, 2017 | 10:34 PM
jabara572's Avatar
Thanks
Here ya go, its an 09.
Old May 18, 2017 | 12:42 PM
mrtee's Avatar
Thanks for the pic, looks great. Is the gap between the fender and headlight OK?
Old May 18, 2017 | 01:29 PM
jabara572's Avatar
It's perfect, don't have a pic but it fits just like the stock one, like it was made for it
Old May 18, 2017 | 01:46 PM
mrtee's Avatar
